Object Selection
CoMan's Selection Tool is the basic tool, which is enabled by default if no other tool is currently active.
The Selection Tool can be started by selecting from the Edit menu of by pressing the corresponding button on the Edit toolbar. Objects that have been selected are marked with red color. Multiple objects can be selected simultaneously by holding the Ctrl key while selecting. In order to select all objects at once, hold the Ctrl key and the A key simultaneously.
