Designate Casting Part
Select the casting parts and define the material, alloy, and temperature.
Microdialog Options
Define the material, alloy, and temperature of the casting parts.
| Option | Description | |
| Material Viewer |
Click |
| Material |
Select from common ferrous and non-ferrous materials. |
| Alloy |
Select from common alloys of the chosen material. |
| Temperature |
Enter the temperature of the material. |
Materials Database
Select a material and an alloy for the casting parts and examine its Fluid, Thermal, Phase-Change, Mechanical, and Advanced-Mechanical properties.
| Material Group |
| Material Name |
| Temperature |
| Property | Description |
| Fluid |
| Thermal |
| Phase-Change |
| Mechanical |
| Advanced-Mechanical |
Note: Most users will not need to modify a material's
Create Material
Customize a material and add it to My Materials.
- Select an alloy to customize.
- Click Edit.
- Edit the Thermal, Fluid, or Phase-Change properties.
- Enter a New Material Name and click Save.
- Click Select to use this material.
Import Material
Import a material from Jmat Pro
