Find entities in the model that contain the search string you enter.Find objects in the scene that contain the search string you enter. The search results are not filtered.
Configure a model by activating or deactivating parts so they are included or excluded from calculations like mass summaries,
static weight calculations, optimization, etc.
Create parametric sketches, geometry, and PolyNURBS with construction history and variables.Create 2D sketches, surfaces and solids, and PolyNURBS.Create 2D sketches, surfaces, and solids.
