Macros
You can record your session actions (in the Editor) as macros to replay them at a
later time using the Macros menu.
Start, Stop and Run Macros
When you are ready to begin recording your session, click .
Compose begins recording your session.
To stop recording, click
To play your current macro, click
To save the current macro, click and enter the name to use.
Select and Run a Saved Macro
Click .
The Select and Run dialog opens.
Use the drop down menu to select the macro to run.
If desired, set the macro to run a specific number of times to run.
Click Run.
Remove a Saved Macro
Click .
The Remove Macro dialog opens.
Use the checkboxes to select the macro to remove.
Click Remove.
