Objects in OpenMatrix Language
Objects in OML are defined using the classdef keyword. This creates a blueprint for an object but does not actually create (instantiate) anything.
- The declaration including the name and parent class.
 - The properties section.
 - The methods section.
classdef MyClass
endclassdef MyClass
    properties
        name
        value
    end
endm = MyClass;
m.name = ‘fun’;
m.value = 0;classdef MyClass
    properties
        name = ‘fun’;
        value = 0;
    end
end
m = MyClass;classdef MyClass
    properties
        name
        value
    end
    methods
        function obj = AddOne(self)
            obj.value = self.value+1;
            obj.name = self.name;
        end
    end
end
m = MyClass;
m.name = ‘fun’;
m.value = 0;
m = m.AddOne();classdef MyClass
    properties
        name
        value
    end
    methods
        function obj = MyClass(in_name, in_value)
             obj.name = in_name;
             obj.value = in_value;
        end
    end
end
m = MyClass(‘fun’, 3);classdef Employee
    properties
        name;
        ID;
    end
    methods
        function obj = Employee (in_name, in_ID)
            obj.name = in_name;
            obj.ID = in_ID;
        end
    end
end
classdef Supervisor < Employee
    properties
        group
    end
    methods
        function obj = Supervisor(in_name, in_ID)
            obj.name = in_name;
            obj.id = in_ID;
            obj.group = {};
        end
    end
end
super = Supervisor(‘Chris’, 4)function obj = Supervisor(in_name, in_ID)
            obj = obj@Employee(in_name, in_ID);
            obj.group = {};
        endclassdef MyClass
    properties
        name
        value
    end
    methods
        end
    end
end
m = MyClass;
m.name = ‘fun’;
m.value = 0;
m = m.AddOne()classdef MyClass < handle
    properties
        name
        value
    end
    methods
        function AddOne(self)
            self.value = self.value+1;
        end
    end
end
m = MyClass;
m.name = 'fun';
m.value = 0;
m.AddOne();
mclassdef ratnum
    properties
	    n
                  d
	end
	methods
	    function r = ratnum(numerator, denomenator)
		    r.n = numerator;
			r.d = denomenator;
		end
		function r = sqrt(r)
		    r = sqrt(r.n/r.d);
		end
	end
end
a = ratnum(2,3);
sqrt(a)In this case, when sqrt is called, the class’s method is used instead of the standard built-in function (which is unaware of user-defined classes).
classdef ratnum
    properties
                  n
                  d
	end
	methods
		    r.n = numerator;
		    r.d = denomenator;
                  end
	    function disp(r)
         	        if (r.d ~= 1)
                          fprintf('%d/%d\n', r.n, r.d);
                      else
		 fprintf('%d\n', r.n);
	        end
                  end
            end
end
a = ratnum(2,3)classdef ratnum
    properties
                  n
                  d
	end
	methods
		    r.n = numerator;
		    r.d = denomenator;
                  end
	    function disp(r)
         	        if (r.d ~= 1)
                      else
	        end
                  end
	    function plus(r1, r2)
	        if (class(r2) == 'ratnum')
	            r = ratnum(r1.n*r2.d + r2.n*r1.d, r1.d * r2.d);
                      elseif (isscalar(r2))
	            r = ratnum(r1.d*r2 + r1.n, r1.d);
	        else
	            r = 0;
	        end
                end
            end
end
ratnum(1,3)+ratnum(1,2)The first parameter to any overloaded method or operator is guaranteed to be of the specified type, but any additional arguments need to be checked and handled by the class developer. In the previous example, r1 is always a ratnum, but r2 can be a ratnum, a scalar, or anything else (for example, a cell array).
 - plus
 - minus
 - mtimes
 - times
 - mrdivide
 - rdivide
 - mldivide
 - ldivide
 - eq
 - ne
 - mpower
 - power
 - uminus
 - unary minus negates a single object instead of subtracting two objects
classdef MyClass
    properties (Access = private)
        name
        value
    end
    methods
             obj.name = in_name;
        end
    end
end
m = MyClass(‘Ted’, 4)
m.name = ‘Bob’ % this triggers a run-time error
