Adding an S-parameter Configuration to Generate a Multiport Data Package
Define an S-parameter configuration to export a multiport data package.
  1. Add an S-parameter configuration using one of the following workflows:
    • On the Request tab, in the Configurations group, click the  S-parameter Configuration icon.
    • In the configuration list, click the icon. Select S-parameter Configuration from the menu .
  2. Select the Generate multiport data package (*.mdp)
    Figure 1. The Create S-Parameters dialog.
    Note: All the ports in the S-parameter configuration are activated.
  3. Follow Step 2 and Step 3 to select the ports and set the properties.
  4. In the Label field, add a unique label for the request.
  5. Click Create to request the S-parameter results and to close the dialog.
  6. [Optional] Add additional requests, for example, far fields, near fields and current requests to the S-parameter configuration to export the data to the multiport data package.
