Visualising PCB Current Data
View the PCB board outline with currents per frequency for a PCB current data definition.
In the model tree, under
Field/Current Data, select a PCB current data. From
the right-click context menu, click
Visualise PCB Current Data.
Figure 1. The Visualise PCB Current Data right-click context menu option.The Visualise PCB Current Data dialog is displayed.
Figure 2. The Visualise PCB Current Data dialog. -
On the Visualise PCB Current Data dialog, in the
Frequencies field, specify the frequencies (values
are in Hz):
Note:
- Leave the field empty to visualise all frequencies.
- Specify a single value:
1e9 - Specify a comma-separated
list:
500 MHz, 2GHz - Specify a frequency range:
1GHz - 2GHz - Use a combination of a comma-separated list and
range:
500 MHz, 2GHz, 1GHz - 2GHz
Click OK to view the PCB
current data in the Feko Source Data Viewer.
Figure 3. The Feko Source Data Viewer where you can view currents per frequency for a PCB current data definition.
