Multilevel Fast Multipole Method (MLFMM)
The multilevel fast multipole method (MLFMM) is a current-based method applicable to electrically large structures.
Use CADFEKO to configure a solver-ready input file for Solver simulations.
View the main elements and terminology in the CADFEKO application window.
CADFEKO has various default settings that you can configure to customise it to your preference.
A number of rendering options are available to ensure that 3D models are rendered efficiently.
Store a CADFEKO model and calculation requests to a .cfx file to reopen later.
3D views are used to display and interact with the model. You can zoom, rotate and pan around a 3D model using the keyboard, mouse or a combination of both. You can use a 3D mouse, specify a view or select specific parts of a model. Multiple 3D views are supported.
Protect a model with a password.
Define the model unit, variables, named points, workplanes and the model extents for the model.
Create fully parametric and complex CAD geometry using canonical structures and perform Boolean operations on these.
The component library contains an extensive list of common components, such as antennas and platforms.
Organise geometry and mesh parts by grouping geometry and mesh in the model tree.
Import a CAD (geometry) model or mesh model from a wide range of industry formats into CADFEKO to save time and development costs.
A CADFEKO model can be exported to a variety of industry standard geometry and mesh formats to be used in other applications.
Define field or current data using either far field data, near field data, spherical mode data or PCB current data. Use the field/current definition when defining an equivalent source or a receiving antenna.
Define a medium with specific material properties, import a predefined medium from the media library or add a medium from your model to the media library.
Defined media can be applied to the model in various ways. Some media settings are applied to regions, others on faces and wires. The rules for defining media varies between the different solution methods.
Use a periodic boundary condition (PBC) to analyse infinite periodic structures. A typical application of PBC is to analyse frequency selective surface (FSS) structures.
Create an arbitrary finite antenna array that consists of an array of contributing elements, either with direct feeds for each element or via indirect coupling, and solve with the efficient domain Green's function method (DGFM).
Use the windscreen tools to define a curved reference surface constrained by a cloud of points, normals and optional U′V′ parameters. The constrained surface is then used as a reference to create a work surface where windscreen layers and curved parameterised windscreen antenna elements can be created.
Many electromagnetic compatibility and interference problems involve cables that either radiate, are irradiated or cause coupling into other cables, devices or antennas. Use the cable modelling tool and solver to analyse the coupling and radiation.
For a frequency domain result, the electromagnetic fields and currents are calculated at a single frequency or frequency range. When the finite difference time domain (FDTD) solver is used, the frequency must be specified to convert the native time domain results to the frequency domain.
The excitation of an antenna is normally specified as a complex voltage, but it may be useful to specify the total radiated or source power instead. The result is then scaled to yield the desired source power level.
A port is a mathematical representation of where energy can enter (source) or leave a model (sink). Use a port to add sources and discrete loads to a model.
A source is used to excite or illuminate the model and cause current to flow.
Complex feed networks can be simplified by including them as a circuit representation using general network blocks.
Perform multiple solutions for a single model using multiple configurations. Multiple configurations remove the requirement to create multiple models with different solution requests.
Before running the Solver, define the output requests and view in the model tree (Configuration tab).
Use an infinite plane or half-space to model a ground plane efficiently. The number of triangles in the model is reduced as the ground plane is not discretised into triangles.
During the design process, the development of a model can introduce a range of issues that can lead to a non-simulation-ready model. Use the validation toolset to verify that the model is simulation-ready or to search, detect and flag discrepancies.
The default solver used in Feko is the method of moments (MoM) - surface equivalence principle (SEP). A solver is specified per model, per face or per region, and depends on the solver in question.
Define and exploit the symmetry in the model (where applicable).
General solver settings are available that relate to geometry tests and data storage precision.
Advanced solver settings are available to reduce the memory footprint or speed up a solution for specific types of models.
For large models, the runtime can be reduced if the solution coefficients are saved during the solution phase and re-used in a subsequent solution.
The MoM is a full wave solution of Maxwell’s integral equations in the frequency domain.
To solve a model with the multilevel fast multipole method (MLFMM), you must activate MLFMM for the model.
A number of optional settings are available when using multilevel fast multipole method (MLFMM) to solve a model.
A few preconditioners are available for the multilevel fast multipole method (MLFMM).
When using the MLFMM, you can specify the integral equation to obtain faster iterative convergence.
The adaptive cross-approximation (ACA) is a fast method, similar to multilevel fast multipole method (MLFMM). The method improves the solution of certain complex method of moments (MoM) problems using less memory and run-time.
The finite element method (FEM) is a volume meshing technique used to model electrically complex or inhomogeneous dielectric bodies.
The physical optics (PO) solver is an asymptotic high-frequency numerical solver based on currents. Use the method in instances where electrically very large metallic structures are modelled.
The ray launching geometrical optics (RL-GO) solver is a ray-based solver that models objects based on optical propagation, reflection and refraction theory.
The uniform theory of diffraction (UTD) is an asymptotic high-frequency numerical solver. The method is typically used for electrically extremely large PEC structures.
The finite difference time domain (FDTD) solver is well suited to modelling inhomogeneous materials and models with wide bandwidths.
The dielectric surface impedance approximation is a solution method that can be applied to homogeneous, lossy dielectric regions. Use the solution method to compute SAR values for a homogeneous phantom.
Specify the command-line parameters for the Feko components.
CADFEKO has a collection of tools that allows you to quickly validate the model, for example, perform calculations using a calculator, measure distances, measure angles and export images.
View the icons that are found in the model tree.
View the icons that are found in the details tree.
View the files associated and generated by CADFEKO.
View the default shortcut keys available for CADFEKO for faster and easier operation of CADFEKO.
ON THIS PAGE
ON THIS PAGE
