Split Ring
Create a split ring to be used either as a primitive or as a building block for constructing complex geometry.
Centre point (C) | The centre point of the ring. |
| Outer radius (R) | The outer radius of the ring. | |
| Inner radius (r) | The inner radius of the ring. | |
| Start angle ( ) | The start angle of the ring. | |
| Gap angle ( ) | The gap angle of the ring. |
