Selection Method
View the list of available selection methods.
| Icon | Icon text | Description |
| Single Select | Select the item under the mouse cursor. | |
| Rectangle Select | Select all items in the rectangle. Click once to place the first corner of the rectangle. Move the mouse cursor and click again to indicate the second point in the rectangle. | |
| Polygon Select | A polygon selection area is defined using successive clicks. The elements inside the polygonal area are selected. |
