Highlighting Specific Mesh Elements
The mesh highlight tool allows you to view areas of the mesh where specific model settings are applied.
None- No mesh elements are highlighted.
Lossy
metal- Highlight mesh elements (faces, wires) with a metallic medium and thickness applied to it.
Coating- Highlight mesh elements (faces, wires, edges) with a coating (layered dielectric) applied to it.
CFIE / MFIE- Highlight mesh elements (faces) with either a combined field integral equation (CFIE) or magnetic field integral equation (MFIE) applied to it.
EFIE- Highlight mesh elements (faces) with the electric field integral equation (EFIE) applied to it.
Impedance
sheet- Highlight mesh elements (wires, faces) with an impedance sheet applied to it.
Surface
impedance approximation- Highlight faces that bound a region set to the dielectric surface impedance approximation.
Physical
Optics- Highlight mesh elements (faces) with the physical optics (PO) solution method applied to it.
Physical
Optics (Fock regions)- Highlight mesh elements (faces) with the physical optics (PO) solution method applied to a Fock region.
Ray
Launching GO- Highlight mesh elements (faces) with the ray launching geometrical optics (RL-GO) solution method applied to it.
Uniform
Theory of Diffraction- Highlight mesh elements (faces) with the uniform theory of diffraction (UTD) solution method applied to it.
Faceted
Uniform Theory of Diffraction- Highlight mesh elements (faces) with the faceted uniform theory of diffraction (faceted UTD) solution method applied to it.
FEM- Highlight mesh elements (regions) with the finite element method (FEM) solution method applied to it.
VEP- Highlight mesh elements (regions) with the volume equivalence principle (VEP) solution method applied to it.
Windscreen
solution elements- Highlight mesh elements (faces, wires) that are specified as windscreen solution elements (windscreen antenna elements).
Aperture- Highlight a slot or aperture in an infinite plane with the planar Green's function aperture applied to it.
Numerical
Green's Function- Highlight mesh elements defined as the static part using the numerical Green's function.
Figure 1. On the left, a 3D view of a horn and a reflector with no highlighting applied. To the right, the reflector is highlighted in yellow to indicate that PO solution method is applied to the face.
