Results viewer can be used to display and analyze results from an XML Result file.
            Results Viewer can be used for:
        To start using Results Viewer click the “Results Viewer” tab, if it is not there, user
            can open it from PostProcessing→Results Viewer. XML Result results if selected objects
            will be displayed in the Results Viewer window.
            Note: To be able to display the results from an XML Result, Results Viewer must first
                process this file. If, for some reason this can’t be done (i.e. because no XML
                Result file was generated by the solver, XML Result file mas manually moved to some
                other folder etc.), an error message will be displayed instead of the results
                information. If this is the case, it is possible for the user to re-generate results
                data from a XML Result (either from the default XML Result that is in the same
                folder with the .flo file or by selecting the XML Result file to be used).
