How to Get the Steps of a Scenario?
Introduction
Some API have been implemented to allow the user to select steps to quickly postprocess. All methods have been added on the structure SCENARIO.
API list
- isPostprocessingOK()
 - getValuesParameter()
 - getIndexStep (String[] parameterNames, double[] values)
 - selectIndexStep(int index)
 - selectFirstStep()
 - selectLastStep()
 - selectNextStep()
 - existNextStep()
 - isValidStep(int index)
isPostprocessingOK
- Initial state: the scenario exists
 - Input: none
 - Output:
- valid: an integer (0 or 1) for (is not OK or OK)
 - Final state: no change
getValuesParameter
- Initial state: the scenario is solved and is multi step
 - Input: none
 - Output:
- a dictionary {key=<String>parameterName, values = <double>parameterValues}
 - Final state: return all parameters values except if scenario has no parameter
getIndexStep
 - Input (use the dictionary obtained by getValuesParameter)
- parameterName: String array dim N (N <= parameter number in the scenario)
 - parameterValue: a double array dim N (N < = parameter number in the scenario)
 - Output:
- an integer array corresponding to step index
selectIndexStep
 - Input (use the integer array gets by getIndexStep)
- index: the index of step
 - Output: none
 - Final state: the project is changed on the required step
selectFirstStep
 - Input: none
 - Output: none
 - Final state: the project is changed on the first step scenario
selectLastStep
 - Input: none
 - Output: none
 - Final state: the project is changed on the last step scenario
selectNextStep
 - Input: none
 - Output: none
 - Final state: the project is changed on a step of the scenario
existNextStep
 - Input: none
 - Output:
- exist: an integer (0 or 1) for (no exist or exist)
isValidStep
 - Output:
- state: an integer (0 or 1) for (invalid or valid)
