Steady State AC Magnetic application: principles
Introduction
This chapter deals with magnetic application ( Steady state AC Magnetic ) and answers the following three questions:
  • What is possible to model with Flux? (Flux capabilities, typical problem, mathematical models)
  • How is a Flux problem described? (description of material media, sources, boundary conditions…)
  • How are results analyzed with Flux? (processed quantities available, explanation of results…)
Reading advice
Before reading this chapter, you should have read the chapter Transient Magnetic application: principles (as well as the chapter Magneto Static application: principles).
Contents
