Dialog boxes: Specialized dialog box
How are the data?
The interaction with the database is done using specific dialog boxes: specialized box, data array.
This paragraph presents an example of specialized box.
Specialized box
In this box the user can enter/check/modify information relating to the data.
A specialized box is presented in the figure below.
The required fields (necessary and sufficient for the definition of the entity) are marked by an asterisk *.
General tools
The general tools available to carry out the data entry are presented in the table below.
Button | Function |
allow the direct access to the non-filled required fields | |
OK | validate information and close the dialog box |
Apply | validate information without closing the dialog box |
Cancel | close the dialog box |
access to the online help concerning the entity |
Specific tools
The user can create a missing entity using the button in a specialized box.
