Paths: definition (structure)
Definition
A path is defined by:
- a name (and a comment)
- a type
- specific characteristics belonging to a type
- a coordinate system for definition
- attributes of color and visibility
Name
The name to identify the path is set by the user during the creation of this one.
A comment (optional) can be added to the name.
Types of path
The different types of paths and the characteristics useful for their description are presented in the table below.
Type | Characteristics | |
path defined by two points |
starting point (coordinates) |
ending point (coordinates) |
Type | Characteristics | |||||||||||
arc path defined by three points |
middle point (coordinates) |
arc defined by center, radius and angles | coordinate system for definition |
center point (coordinates) |
radius |
starting angle ending angle |
parametrized path | coordinate system for definition |
functions (coordinates dependent on parameter) |
parameter variation (minimum and maximum) |
It is not possible to modify a path.
