Passive components: resistor, inductor, capacitor
Introduction
The passive components are of three types:
  • the resistor
  • the coil
  • the capacitor
Utilization
The passive components are used in the Steady State AC Magnetic and the Magnetic Transient applications.
Characteristic
The current-voltage characteristic for each of these different components is mentioned again in the table below.
Component
Current-voltage
characteristic
Characteristic quantity Initial value
resistor R is the value of the resistance in (in Ω )
coil L is the value of the coil inductance (in H)
Initial current
I (t = 0)
capacitor C is the value of the capacitance (in F)
Initial voltage
U (t = 0)
where:
  • U(t) is the voltage at the terminals of the component (in V)
  • I(t) is the current flowing through the component (in A)
