Bidirectional Conductor: mesh
Types of mesh
In order to mesh the bidirectional conductors , a single type of discretization of the plane of current flow is provided. It is a manual mesh type with a uniform distribution of the elements.
Uniform mesh
A mesh with uniform distribution of elements (elements of the same size) is characterized by a number of elements along the two directions of the conductor.
The rectangle encompassing the plate is uniformly meshed with numbers n and m of the PEEC elements that the user has previously indicated.
This can lead at the borders to:
- generate meshes with a portion of their section outside the conductor contour
- neglect some areas of the conductor surface. Indeed, the meshes, possibly added to cover these areas, would have a large part of their section outside the conductor contour
