Select a step of the scenario
Introduction
To carry out the results post-processing on a computation step, the user has to select a computation step of the scenario. Then, he carries out the results post-processing on this step as in the case of a mono-step solving process.
Select a computation step of the scenario
To select a computation step of the scenario, the user has to:
Step Action
1 Click on the button Select the step in the box located in the left bottom corner of the screen
2
In the dialog box Select step and scenario:
  • select a computation step
Note: in each Flux PEEC application, only one scenario exists: it is created at the definition of the application.
Scenario states
States of a solving scenario can be as follows:
  • unprocessed (not processed yet)
  • fully processed (all the steps are processed)
