Propagate faces / Propagate volumes
Before starting
It is necessary to have a transformation (created beforehand) and faces / volumes to be able to propagate faces / volumes.
Propagate faces / volumes
To propagate faces / volumes:
Step Action
1
Select the faces / volumes to propagate:
  • in the Select menu click on Select faces / Select volumes
    (or on the icon / )
  • in the graphic scene click on the face / volume of interest
    (Keep pressed the Ctrl key for a multiple selection.)
2
Activate the command *:
  • open the contextual menu with the right mouse button
  • click on Propagate faces / Propagate volumes in the contextual menu
→ A new dialogue box is opened.
3
Fill out the fields:
  • choose a transformation
  • enter the number of the successive executions of the transformation
  • choose building option
    Warning: To build toroidal, spherical, helical faces / volumes use one of the building options which includes the creation of faces / volumes (Add Faces … , Add Volumes … ).
  • choose the option for the preparation of regions (optional)
    Note: To propagate regions:
    • for the case no propagated region (by default): it is useless to fill out the fields periodicity and suffix
    • for the other cases: see tables for the preparation of regions
4
Validate the information:
  • click on OK button
→ The new entities created (points, lines, faces, volumes) depend on the selected option.
→ A new dialog box for the extrusion of entities of the same type is automatically opened.
5
Quit the sequence:
  • click on Cancel button
Note: * You can also activate the propagation command by clicking on Propagate faces / Propagate volumes in the menu Geometry > Propagate (or on the icon / ).
