Correction and simplification of the geometry
Introduction
This section describes the possibilities to correct and simplify the geometry created by the Assimilation Conductor mode: intersection between lines, idle points…
These tools are not available for geometry created by the Tube Conductor mode, i.e. for Tube Points, Tube Lines,…
Contents
This section contains the following topics:
