Delete / Force delete
To delete … use the command …
independent entities (non-connected with other entities)
Delete
any entity + all connected entities
Force delete
Delete entities
To delete / delete in force an entity or several entities:
Step Action
1 Activate the Delete / Force delete command (see next block)
A confirmation box is open.
2
Confirm the deletion:
  • click on OK
Activate the command
To activate the Delete / Force delete command, which requires data selection, choose one of the methods presented in the figure below:
Note:
  • To open a contextual menu, use the right button of the mouse.
  • For multiple selections, keep the Ctrl key pressed.
