Mechanical set: definition (structure)
A mechanical set is defined by:
- a name (and a comment)
- a type of mechanical set
and for the mechanical sets of rotation around one axis and translation along one axis :
- an axis of rotation or translation
- a type of kinematics (= computation mode)
- kinematic characteristics:
- general characteristics
- internal characteristics
- external characteristics
- mechanical stops
Types of mechanical set
Different types of mechanical sets are presented in the table below.
Type | enables the regrouping of the regions corresponding to … |
fixed | the motionless parts |
compressible |
the zone of air in which the moving part is in motion |
rotation around one axis |
the moving parts in rotation around an axis |
translation along one axis |
the moving parts in translation along an axis |
free movement | The free motion is designed to take into account complex motions (excluding translation and rotation movement). This motion is described by a list of positions for the mobile part |
six degrees of freedom | In space, using an orthonormal coordinate system (O,x,y,z), the 6
degrees of freedom are defined as follows:
Types of kinematics
Different types of kinematics (= computation mode) are presented in the table below.
Kinematics (= computation mode) … | |
of type … | enables the realization of a computation … |
Multi static |
of multi-position type in Magneto Static application ( |
Imposed speed | at imposed speed in Transient Magnetic application |
Imposed position | at imposed position in Transient Magnetic application |
Coupled load |
with magneto-mechanical coupling in Transient Magnetic application |
Multiphysics | to be able to coupling the motion with another software (like Activate) |
General characteristics
General characteristics gather following information:
- initial conditions (initial speed and initial position)
Internal characteristics
Internal characteristics gather following information:
- kinematic characteristics relating to the moving part (proper characteristics) (see table below)
Motion | Characteristics relating to the moving part | |
rotating | moment of inertia |
resistant torque (formula or 3 coefficients) |
translating | mass |
External characteristics
External characteristics gather following information:
kinematic characteristics relating to the coupled load (external device)
(see table below)
Motion | Characteristics relating to the coupled load | |
resistant force (formula or 3 coefficients) |
Mechanical stops
The various mechanical stops are following:
- minimal stop
- maximal stop
