Flux in SimLab : 2D Examples
| Solution | Example | Description | Illustration |
| 2D Transient Magnetic  |
                        Brushless IPM motor | The studied device, a brushless AC embedded permanent magnet motor
                            presented in the figure in the right, includes the following elements:
                        Brushless SPM motor |
                             The studied device, a brushless DC motor with surface permanent magnet, includes the following elements:
                             Multi-physics (EM, NVH, CFD) Analysis of a 75 kW PMSM - Motor Mode  |
                        The studied device, a 75-kW permanent magnet synchronous machine, is
                            running in motor mode. As presented in the figure in the right, it
                             EM-CFD Coupling Analysis of a 75 kW PMSM (Air Cooling) - Generator Mode  |
                            running in generator mode. As presented in the figure in the right, it
