Formula with geometric parameters
Definition
A formula with geometric parameters is an expression that allows handling geometric parameters in different contextsgeometry, mesh, physics.
Use
A formula with geometric parameters is used to define:
  • a geometric parameter
  • a parameterized quantity: the coordinate of a point, the position of a coordinate system, …
Evaluation
The parameterized expression is “directly” evaluated during the creation of concerned entities.
The example below shows the use of a formula in the geometry context
The circumference of a circle is equal with 2* π *R, where R is the radius of the circle.
The geometric parameter CIRC can be written as function of another geometric parameter (RADIUS) by using the following formula (or expression):
CIRC = 2*PI*RADIUS
Formula and context
The use of these formulas in different working contexts is explained in the table below.
In the context of … the formulas are used to define …
Geometry
  • geometric parameters
  • coordinate systems
  • transformations
  • points
Mesh
  • mesh points
  • mesh line of type:
  • Length of line elements at extreme points
  • Geometric with minimum distance
Physics
  • coordinate systems for anisotropic materials, non-meshed coils, field sources
  • non-meshed coils
