Merge faces / Merge lines
Before starting
It is necessary to open the context for healing of facet geometry as follows:
Step Action
1
Pass to the healing mode:
  • in the Geometry menu click on Context healing of facet geometry
→ The healing mode for geometry is activated.
Note: Click on to go back.
Merge faces
To merge faces after having imported a file with NASTRAN, PATRAN, IDEAS, or MED format:
Step Action
1
Activate the command:
  • in the Healing menu, point on Merge faces and click on Merge …
→ A dialog box Merge … is opened.
2
Useless for Merge all faces with Angle
Select faces to merge:
  • click on the icon and in the graphic zone click directly on the faces of interest keeping pressed the Ctrl key
3
Useless for Merge a list of faces
Fill in the text zone:
  • enter the value of angle
4
Confirm:
  • click on OK
→ The faces are merged.
→ A dialog box Merge … is automatically opened.
5
Exit the sequence:
  • click on Cancel
Merge lines
To merge lines:
Step Action
1
  • in the Healing menu, click on Merge all lines with Angle
2
3
Confirm:
  • click on OK
→ The lines are merged.
4
Exit the sequence:
  • click on Cancel
