Coupled applications in Flux
SM coupled with TT (2D / 3D)
The characteristics of the Steady State AC Magnetic (SM) coupled with the Transient Thermal (TT) application are detailed in the following chapter: “Steady State AC Magnetic coupled with Transient Thermal application: principles”.
SE coupled with TT (2D)
The characteristics of the Steady state AC Electric (SE) coupled with the Transient Thermal (TT) application are not detailed in this paper. This coupling operates similarly to the Steady State AC Magnetic (SM) coupled with the Transient Thermal (TT) application.
Attention: the properties depending on temperature (permeability depending on temperature) must be defined by a user subroutine.
EC coupled with TT (2D)
The characteristics of the Electric Conduction (EC) coupled with the Transient Thermal (TT) application are not detailed in this paper.
This coupling is, a priori, more simple than the “SM coupled with TT application” and the “SE coupled with TT application”, as the solving of the problem with the Electric Conduction application is of a linear type.
