Limitations and remarks
Introduction
This section presents the limitation and remarks concerning the HyperMesh (and OptiStruct) and SimLab mesh import
Other possibilities
The HyperMesh and SimLab mesh import feature offers the following possibilities:
  • Shell mesh import without air box (surface elements) or with air box (surface and volume elements)
  • 2D mesh import (& complete infinite box) in Flux 2D
Remarks and limitations
Some remarks and limitations about HyperMesh and SimLab mesh import are presented :
  • Only one import is allowed
  • In case of 2 nd order mesh import, the “complete infinite box” algorithm renumber the 2 nd order nodes. This limitation is to take into account for coupling.
  • The “complete infinite box” algorithm works after mesh import with MeshGems mesher (mesher by default), but it does not work with Delaunay mesher
  • In case of remeshing (mesh lines / faces / volume / domain) or deleting the mesh, the imported mesh is preserved as long as the “mesh object” exists
Limitations linked to the method
The mesh import presents limitations that cannot be corrected (linked to the method and technical constraints):
  • It is impossible to parameterize a mesh imported with geometrical parameters
  • It is impossible to enter in the Modeler context (also after deleting the mesh)
