Magnetic behavior of materials: definitions
Definition
The macroscopic dependence linking the local values of the vector quantities magnetization M (or magnetic polarization J ) and the magnetic field strength H in any point of a material is called the law of material magnetic behavior.
This law renders the fact that the magnetization of matter is modified under the effect of a magnetic field.
This law is written in the form:
  • with the magnetization vector
  • with the polarization vector
where χm is the scalar or the tensor of magnetic susceptibility*
Attention: * the quantity χm depends on H; χm should be written in the form χm(H) in all the relationships above.
Notation
The magnetization law is written in the form:
where μ is the scalar or the tensor of permeability
Attention: * the quantities χm, μr, μ should be written in the form χm(H), μr(H), μ(H) in all the relationships above.
Complex permeability
In the case of harmonic applications, a complex representation of permeability is used.
The quantity μ can be expressed by the complex permeability:
μ = μ' - j μ"
where:
  • μ' corresponds to the real part of the complex permeability
  • μ" corresponds to the imaginary part of the complex permeability
