Isotropic / anisotropic materials
Introduction
The studied materials can be isotropic or anisotropic. In other words, the magnetic behavior of the material is as follows:
- independent of the direction of the applied field (isotropic material)
- dependent on the direction of the applied field (anisotropic material)
These two cases are presented in the following sections.
Isotropic materials
Isotropic materials are characterized by a magnetization law independent of the direction of the applied field.
The and vectors are always collinear.
The dependence between and is a scalar relationship, which is written as: J= σ.E or E= ρ.J
Anisotropic materials
Anisotropic materials are characterized by a law, which is dependent on the direction of the applied field.
The and vectors are not collinear.
The dependence between and is a vector relationship, which is written as: or
with σ conductivity tensor:
or ρ resistivity tensor:
… in Flux
The model provided in Flux is a simplified model.
The vector dependence between and which is written as:
or can therefore be expressed:
either under the form of three curves: Jx(Ex), Jy(Ey), Jz(Ez)
The conductivity tensor is then written:
or under the form of three curves: Ex(Jx), Ey(Jy), Ez(Jz)
The resistivity tensor is then written:
