Import formats
Import formats
The following table summarizes the different file formats accepted in Flux, associated with the type of import:
Type of import Available File formats Extension Type of format
geometry import called « standard » IGES (Initial Graphics Exchange Specification) *.IGES, *.IGS standard
STEP (Standard for Exchange of Product) *.STEP, *.STP
DXF (Draw eXchange File) *.DXF
STL (STereo Lithography) *.STL
FBD (Flux 2D géométrie) *.FBD proprietary
mesh import NASTRAN neutral *.NAS, *.DAT standard
PATRAN neutral *.PAN, *.DAT
UNV (UNiVersel Ideas Master Serie) *.UNV
MED (Model of data exchange) *.MED
HyperMesh/SimLab/OptiStruct (Nastran format) *.BDF, *.BLK, *.BULK, *.DAT, *.FEM, *.NAS, *.NASTRAN
geometry import called « advanced mode » IGES (Initial Graphics Exchange Specification) *.IGES, *.IGS standard
SAT *.SAT proprietary
CATIA V4 *.MODEL
CATIA V5 *.CATPRODUCT, *.CATPART
INVENTOR *.IPT
PROE (Pro Engineer) *.ASM , *.PRT
Supported versions
The following table summarize the versions supported by ACIS R22 version (geometry kernel) for different import formats.
Type of import File format Supported versions
geometry import called « advanced mode » IGES (Initial Graphics Exchange Specification) IGES versions up to 5.3
STEP (Standard for Exchange of Product) STEP AP203, AP214 (geometry only)
SAT Up to ACIS R22
CATIA V4 CATIA 4.1.9 to CATIA 4.2.4
CATIA V5 CATIA V5 R6 – R20
PROE (Pro Engineer) Pro/E 16 to Wildfire 5
Type of accepted file
For import Flux accepts only files in text format. The binary files are not accepted.
Avertissement : It is not possible to import an assembly file consisting of several IGS files (*_ASM.IGS).
Multiple import
Multiple imports are available. Flux is able to import the files with different formats (DXF, STL, etc) in the same project.
