Bibliographical References
Shape Optimization:
- Ghantasala, Aditya, et al., “”Realization of a Framework for Simulation-Based Large-Scale Shape Optimization Using Vertex Morphing.” Journal of Optimization Theory and Applications 189.1, 2021, pp. 164-189.
 - Firl, M., Wüchner, R. & Bletzinger, KU. Regularization of shape optimization problems using FE-based parametrization. Struct Multidisc Optim47, 507–521 (2013). https://doi.org/10.1007/s00158-012-0843-z
 - Bletzinger, KU. A consistent frame for sensitivity filtering and the vertex assigned morphing of optimal shape. Struct Multidisc Optim49, 873–895 (2014). https://doi.org/10.1007/s00158-013-1031-5
 - Gangl, P. “Sensitivity-Based Topology and Shape Optimization with Application to Electrical Machines”,PhdThesis, Johannes Kepler Universität Linz,2016
 - F. Vi, P. Ferrouillat, J. Siau, A. Rodriguez, Y. Le Floch, R. Fleury, N. Pagaldipti, M. Zhou. Shape Optimization for non linear electromagnetics simulations Application to a switched reluctance motor, Compumag 2022, 2022.
 - OptiStruct online documentation: https://2021.help.altair.com/2021.1/hwsolvers/os/index.htm
