Example of .Rep File
The .rep file may look something like the example shown below.
##  Copyright (c) 1994-2022 ALTAIR Engineering, Inc.
##  All rights reserved.
##  This source code is confidential and may not be disclosed.
# "WindTunnel.rep": Generate a report for the WindTunnel problem
#   To get a report, execute:
#   acuReport -problem IM -file WindTunnel.rep -pdf
import  acuCnf
import  acuUnit
import  string
import  glob
import  os
import  os.path
import  copy
import  re
import  acupu
import  time
import  math
import  inspect
import  numpy
import  sys
import  shutil
import  subprocess
from    acuFvx              import  AcuFvx, AcuPlot
from    acuXmlParReader     import  AcuXmlParReader
from    acuUtil             import  cnvStr2Val
# getMaxFileInd:
def getMaxFileInd( prefix, suffix ):
    ind     = -1
    maxInd  = -1
    prefix = prefix + "."
    suffix = "." + suffix
    searchStr   = str(prefix) + '*[0-9]' + str(suffix)
    fileList    = glob.glob(        searchStr               )
    if len( fileList ) == 0: return -1
    for mFile in fileList:
        preFile = string.split(     mFile,      str(prefix) )
        if len( preFile ) == 2:
            sufFile = string.split( preFile[1], str(suffix) )
            if len( sufFile ) == 2:
                try:
                    ind = int( sufFile[0] )
                    if ind > maxInd:
                        maxInd = ind
                except:
                    pass
    return maxInd
# getListVals: Get the entries of a list
def getListVals( lstStrVal ):
    """ Get the array value.
        Argument:
            aryStrVal   - a sting contains array value
        Output:
            aryVal      - Tha array values
    parValue    = []
    strLst      = lstStrVal.split(',')
    for item in strLst:
        item    = \
         item.split('(')[-1].split(')')[0].strip().split('\"')[1].strip()
        parValue.append( item )
    return parValue
    # Check the end of the array values and put "," after the last value
    # if does not exist. It needed for findall()
    if not _endAryReg.match( aryStrVal ):
        indx        = aryStrVal.find(           "]"                     )
        if indx == -1:
            indx    = aryStrVal.find(           ")"                     )
        aryStrVal   = aryStrVal[:indx] + "," + aryStrVal[indx:]
    parValue        = []
    lstVals         = re.findall(        _aryVals,   aryStrVal          )
    for val in lstVals:
        value       = val #float(               val[0]                  )
        parValue.append(                        value                   )
    return parValue
# getArrayVals: Get the array Value
def getArrayVals( aryStrVal, _endAryReg, _aryVals ):
        Argument:
        Output:
        if indx == -1:
    parValue        = []
    for val in lstVals:
        value       = float(                    val[0]                  )
        unit        = val[1].strip(                                     )
        if unit != "":
            value   = acuUnit.convert(          value,      unit        )
    return parValue
# dict2Val
def dict2Val( dict1 ):
    return cnvStr2Val( dict1['type'], dict1['value'] )
# Read Vars
def readVars( fileName, wtComps ):
    hmDic       = {}
    parDic      = {}
    fsiDic      = {}
    if not os.path.exists( fileName ):
        for compName in wtComps:
            hmDic[compName] = compName
        return ( hmDic, parDic )
    reader  = AcuXmlParReader( None, fileName = fileName )
    parDic  = reader.getElementsDic( "ACS_PARS" )['ACS_PARS']
    if 'ACS_FLEXIBLE_BODIES' in parDic:
        for comp in parDic['ACS_FLEXIBLE_BODIES']:
            component = dict2Val(
                        parDic['ACS_FLEXIBLE_BODIES'][comp]['component'])
            fsiDic[comp] = []
            for item in component:
                fsiDic[comp].append( item )
    return ( hmDic, parDic, fsiDic )
# Get Time History Info
def getMonitorPoints( parDic ):
    othDir      = {}
    defVar      = []
    defLgndRng  = []
    if 'time_history_variables' in parDic['ACS_GLOBAL']:
        defVar = dict2Val(parDic['ACS_GLOBAL']['time_history_variables'])
    if 'time_history_legend_range' in parDic['ACS_GLOBAL']:
        defLgndRng = dict2Val(
                       parDic['ACS_GLOBAL']['time_history_legend_range'])
    if 'ACS_TIME_HISTORY_OUTPUTS' in parDic:
        for item in parDic['ACS_TIME_HISTORY_OUTPUTS']:
            othDir[item]            = {}
            othDir[item]['coords']  = dict2Val(
                parDic['ACS_TIME_HISTORY_OUTPUTS'][item]['coordinates'])
            othDir[item]['output']  = {}
            othDir[item]['legend_range'] = {}
            lgndRng = []
            if 'legend_range' in parDic['ACS_TIME_HISTORY_OUTPUTS'][item]:
                lgndRng = dict2Val(
                parDic['ACS_TIME_HISTORY_OUTPUTS'][item]['legend_range'])
            if 'variables' in parDic['ACS_TIME_HISTORY_OUTPUTS'][item]:
                vars = dict2Val(
                    parDic['ACS_TIME_HISTORY_OUTPUTS'][item]['variables'])
                for var in vars:
                    othDir[item]['output'][var] = []
                    try:
                        if lgndRng != []:
                            if isinstance(lgndRng[0], list):
                                othDir[item]['legend_range'][var] = \
                                            [lgndRng[vars.index(var)][0],
                                            lgndRng[vars.index(var)][1]]
                            else:
                                                [lgndRng[0],lgndRng[1]]
                    except:
                            ['Auto','Auto']
            else:
                for var in defVar:
                    try:
                        if defLgndRng != []:
                            if isinstance(defLgndRng[0], list):
                                        [defLgndRng[defVar.index(var)][0],
                                        defLgndRng[defVar.index(var)][1]]
                            else:
                                    [defLgndRng[0],defLgndRng[1]]
                    except:
                            ['Auto','Auto']
    return othDir
# Get Drag Info
def createResultData(   rep,    adb,    compMap,
                        parDic, fsiDic, othDir,
                        rho,    Aref,   fDir=0,
                        tDir=1, cDir=2
    try:
        os.mkdir('Figures')
    except:
        pass
    fsiFlag     = False
    if 'fsi' in parDic['ACS_GLOBAL']:
        if dict2Val(parDic['ACS_GLOBAL']['fsi']):
            fsiFlag = True
    osiNames    = adb.getOsiNames()
    osiVars     = adb.getOsiVarNames()
    thPrts      = adb.getOthNames()
    othVars     = adb.getOthVarNames()
    bdyPrts     = []
    whlPrts     = []
    prsPrts     = []
    fsiPrts     = {}
    nFsiComps   = 0
    if 'ACS_COMPONENTS' in parDic:
        for comp in parDic['ACS_COMPONENTS']:
            if comp in osiNames or \
               comp + " tri3 Fluid tet4" in osiNames:
                if dict2Val(
                 parDic['ACS_COMPONENTS'][comp]['wtcomp']).find('WHEEL')\
                 != -1:
                    whlPrts.append( comp )
                if dict2Val(
                 parDic['ACS_COMPONENTS'][comp]['wtcomp']).find('BODY')\
                 != -1:
                    bdyPrts.append( comp )
                if dict2Val(
                 parDic['ACS_COMPONENTS'][comp]['wtcomp']).find('WT_INLET')\
                 != -1:
                    inPrt = comp
                if dict2Val(
                 parDic['ACS_COMPONENTS'][comp]['wtcomp']).find('POROUS')\
                 != -1:
                    comp = "%s tri3 Fluid tet4" % comp
                    prsPrts.append( comp )
            else:
                if 'surface_output' in parDic['ACS_COMPONENTS'][comp]:
                    srfout = dict2Val(
                        parDic['ACS_COMPONENTS'][comp]['surface_output'])
                    if not srfout:
                        print "%s surface output is not active" % comp
                    else:
                        print "%s surface output does not exist" % comp
            fsiPrts[comp] = []
                fsiPrts[comp].append( item )
    nBdyPrts    = len( bdyPrts )
    nWhlPrts    = len( whlPrts )
    nPrsPrts    = len( prsPrts )
    nFsiPrts    = 0
    #fsiPrts    = fsiDic
    for item in fsiPrts:
        nFsiPrts= nFsiPrts + len( fsiPrts[item] )
    Uin     = adb.getOsiValues( inPrt ,"velocity")
    Ux      = Uin[:,0]
    Uy      = Uin[:,1]
    Uz      = Uin[:,2]
    Usum    = Ux*Ux + Uy*Uy + Uz*Uz
    U       = numpy.sqrt( Usum )
    Dr      = 0.5 * rho * U * U * Aref
    nSteps   = adb.get('nOsiSteps',1)
    osiSteps = adb.get('osiSteps',1)
    osiTimes = adb.get('osiTimes',1)
    DragBody        = {}
    DragAreaBody    = {}
    LiftBody        = {}
    CrossBody       = {}
    DragBodyAvg     = {}
    DragAreaBodyAvg = {}
    LiftBodyAvg     = {}
    CrossBodyAvg    = {}
    TotDragBody     = numpy.zeros( nSteps, dtype='d' )
    TotDragAreaBody = numpy.zeros( nSteps, dtype='d' )
    TotLiftBody     = numpy.zeros( nSteps, dtype='d' )
    TotCrossBody    = numpy.zeros( nSteps, dtype='d' )
    TotDrag         = numpy.zeros( nSteps, dtype='d' )
    TotDragArea     = numpy.zeros( nSteps, dtype='d' )
    TotLift         = numpy.zeros( nSteps, dtype='d' )
    TotCross        = numpy.zeros( nSteps, dtype='d' )
    As  = 1
    if nSteps > 50:
        if 'avg_iter_coefficient' in parDic['ACS_GLOBAL']:
            As  = dict2Val(parDic['ACS_GLOBAL']['avg_iter_coefficient'])
        else:
            As  = 50
    for bdyPrt in bdyPrts:
        trc                     = adb.getOsiValues( bdyPrt, "traction" )
        DragBody[bdyPrt]        = trc[:,fDir] / Dr
        DragAreaBody[bdyPrt]    = DragBody[bdyPrt] * Aref
        LiftBody[bdyPrt]        = trc[:,tDir] / Dr
        CrossBody[bdyPrt]       = trc[:,cDir] / Dr
        TotDragBody             = TotDragBody + DragBody[bdyPrt]
        TotDragAreaBody         = TotDragAreaBody + DragAreaBody[bdyPrt]
        TotLiftBody             = TotLiftBody + LiftBody[bdyPrt]
        TotCrossBody            = TotCrossBody + CrossBody[bdyPrt]
        TotDrag                 = TotDrag + DragBody[bdyPrt]
        TotDragArea             = TotDragArea + DragAreaBody[bdyPrt]
        TotLift                 = TotLift + LiftBody[bdyPrt]
        TotCross                = TotCross + CrossBody[bdyPrt]
        DragBodyAvg[bdyPrt]     = DragBody[bdyPrt][-As:].mean()
        DragAreaBodyAvg[bdyPrt] = DragAreaBody[bdyPrt][-As:].mean()
        LiftBodyAvg[bdyPrt]     = LiftBody[bdyPrt][-As:].mean()
        CrossBodyAvg[bdyPrt]    = CrossBody[bdyPrt][-As:].mean()
    DragPorous          = {}
    DragAreaPorous      = {}
    LiftPorous          = {}
    CrossPorous         = {}
    DragPorousAvg       = {}
    DragAreaPorousAvg   = {}
    LiftPorousAvg       = {}
    CrossPorousAvg      = {}
    TotDragPorous       = numpy.zeros( nSteps, dtype='d' )
    TotDragAreaPorous   = numpy.zeros( nSteps, dtype='d' )
    TotLiftPorous       = numpy.zeros( nSteps, dtype='d' )
    TotCrossPorous      = numpy.zeros( nSteps, dtype='d' )
    for prsPrt in prsPrts:
        trc                     = adb.getOsiValues( prsPrt,
                                                    "traction"          )
        mtm                     = adb.getOsiValues( prsPrt,
                                                    "momentum_flux"     )
        DragPorous[prsPrt]      = (trc[:,fDir] + mtm[:,fDir]) / Dr
        DragAreaPorous[prsPrt]  = DragPorous[prsPrt] * Aref
        LiftPorous[prsPrt]      = (trc[:,tDir] + mtm[:,tDir]) / Dr
        CrossPorous[prsPrt]     = (trc[:,cDir] + mtm[:,cDir]) / Dr
        TotDragPorous           = TotDragPorous + DragPorous[prsPrt]
        TotDragAreaPorous       = TotDragAreaPorous \
                                                + DragAreaPorous[prsPrt]
        TotLiftPorous           = TotLiftPorous + LiftPorous[prsPrt]
        TotCrossPorous          = TotCrossPorous + CrossPorous[prsPrt]
        TotDrag                 = TotDrag  + DragPorous[prsPrt]
        TotDragArea             = TotDragArea + DragAreaPorous[prsPrt]
        TotLift                 = TotLift  + LiftPorous[prsPrt]
        TotCross                = TotCross + CrossPorous[prsPrt]
        DragPorousAvg[prsPrt]   = DragPorous[prsPrt][-As:].mean()
        DragAreaPorousAvg[prsPrt] = DragAreaPorous[prsPrt][-As:].mean()
        LiftPorousAvg[prsPrt]   = LiftPorous[prsPrt][-As:].mean()
        CrossPorousAvg[prsPrt]  = CrossPorous[prsPrt][-As:].mean()
    DragWheel       = {}
    DragAreaWheel   = {}
    LiftWheel       = {}
    CrossWheel      = {}
    DragWheelAvg    = {}
    DragAreaWheelAvg= {}
    LiftWheelAvg    = {}
    CrossWheelAvg   = {}
    TotDragWheel    = numpy.zeros( nSteps, dtype='d' )
    TotDragAreaWheel= numpy.zeros( nSteps, dtype='d' )
    TotLiftWheel    = numpy.zeros( nSteps, dtype='d' )
    TotCrossWheel   = numpy.zeros( nSteps, dtype='d' )
    for whlPrt in whlPrts:
        trc                     = adb.getOsiValues( whlPrt, "traction" )
        DragWheel[whlPrt]       = trc[:,fDir] / Dr
        DragAreaWheel[whlPrt]   = DragWheel[whlPrt] * Aref
        LiftWheel[whlPrt]       = trc[:,tDir] / Dr
        CrossWheel[whlPrt]      = trc[:,cDir] / Dr
        TotDragWheel            = TotDragWheel  + DragWheel[whlPrt]
        TotDragAreaWheel        = TotDragAreaWheel \
                                                + DragAreaWheel[whlPrt]
        TotLiftWheel            = TotLiftWheel  + LiftWheel[whlPrt]
        TotCrossWheel           = TotCrossWheel + CrossWheel[whlPrt]
        TotDrag                 = TotDrag + DragWheel[whlPrt]
        TotDragArea             = TotDragArea + DragAreaWheel[whlPrt]
        TotLift                 = TotLift + LiftWheel[whlPrt]
        TotCross                = TotCross + CrossWheel[whlPrt]
        DragWheelAvg[whlPrt]    = DragWheel[whlPrt][-As:].mean()
        DragAreaWheelAvg[whlPrt]= DragAreaWheel[whlPrt][-As:].mean()
        LiftWheelAvg[whlPrt]    = LiftWheel[whlPrt][-As:].mean()
        CrossWheelAvg[whlPrt]   = CrossWheel[whlPrt][-As:].mean()
    DragFsi             = {}
    DragAreaFsi         = {}
    LiftFsi             = {}
    CrossFsi            = {}
    DragFsiAvg          = {}
    DragAreaFsiAvg      = {}
    LiftFsiAvg          = {}
    CrossFsiAvg         = {}
    TotDragFsi          = {}
    TotDragAreaFsi      = {}
    TotLiftFsi          = {}
    TotCrossFsi         = {}
    MeshXDisplacement   = {}
    MeshYDisplacement   = {}
    MeshZDisplacement   = {}
        TotDragFsi[item]            = numpy.zeros( nSteps, dtype='d' )
        TotDragAreaFsi[item]        = numpy.zeros( nSteps, dtype='d' )
        TotLiftFsi[item]            = numpy.zeros( nSteps, dtype='d' )
        TotCrossFsi[item]           = numpy.zeros( nSteps, dtype='d' )
        MeshXDisplacement[item]     = numpy.zeros( nSteps, dtype='d' )
        MeshYDisplacement[item]     = numpy.zeros( nSteps, dtype='d' )
        MeshZDisplacement[item]     = numpy.zeros( nSteps, dtype='d' )
        for fsiPrt in fsiPrts[item]:
            trc                     = adb.getOsiValues( fsiPrt,
                                                    "traction"          )
            disp                    = adb.getOsiValues( fsiPrt,
                                                    "mesh_displacement" )
            DragFsi[fsiPrt]         = trc[:,fDir] / Dr
            DragAreaFsi[fsiPrt]     = DragFsi[fsiPrt] * Aref
            LiftFsi[fsiPrt]         = trc[:,tDir] / Dr
            CrossFsi[fsiPrt]        = trc[:,cDir] / Dr
            TotDragFsi[item]        = TotDragFsi[item] + DragFsi[fsiPrt]
            TotDragAreaFsi[item]    = TotDragAreaFsi[item] \
                                                    + DragAreaFsi[fsiPrt]
            TotLiftFsi[item]        = TotLiftFsi[item] + LiftFsi[fsiPrt]
            TotCrossFsi[item]       = TotCrossFsi[item] \
                                                    + CrossFsi[fsiPrt]
            TotDrag                 = TotDrag + DragFsi[fsiPrt]
            TotDragArea             = TotDragArea + DragAreaFsi[fsiPrt]
            TotLift                 = TotLift + LiftFsi[fsiPrt]
            TotCross                = TotCross + CrossFsi[fsiPrt]
            DragFsiAvg[fsiPrt]      = DragFsi[fsiPrt][-As:].mean()
            DragAreaFsiAvg[fsiPrt]  = DragAreaFsi[fsiPrt][-As:].mean()
            LiftFsiAvg[fsiPrt]      = LiftFsi[fsiPrt][-As:].mean()
            CrossFsiAvg[fsiPrt]     = CrossFsi[fsiPrt][-As:].mean()
            MeshXDisplacement[item] = MeshXDisplacement[item] + disp[:,0]
            MeshYDisplacement[item] = MeshYDisplacement[item] + disp[:,1]
            MeshZDisplacement[item] = MeshZDisplacement[item] + disp[:,2]
    print "plotting time history"
    timeHistory_Disp                    = {}
    othVarNms = othVars
    if 'velocity' in othVars:
        othVarNms = othVarNms + [ 'x_velocity', 'y_velocity',
                        'z_velocity', 'velocity_magnitude' ]
    if 'mesh_displacement' in othVars:
        othVarNms = othVarNms + [ 'x_mesh_displacement',
                        'y_mesh_displacement', 'z_mesh_displacement' ]
    def which(lst, var):
        for element in lst:
            if element in var:
                return element
        return False
    coordDic    = { "x_" : 0, "y_" : 1, "z_" : 2 }
    scalarVar   = [ '_magnitude' ]
    for entryName, entry in othDir.iteritems():
        if entryName not in thPrts:
            print "monitor point %s not in database!" % entryName
            continue
        if 'velocity' in entry['output']:
                if 'x_velocity' not in entry['output']:
                    entry['output'][u'x_velocity'] = []
                    entry['legend_range'][u'x_velocity'] = \
                        entry['legend_range'][u'velocity']
                if 'y_velocity' not in entry['output']:
                    entry['output'][u'y_velocity'] = []
                    entry['legend_range'][u'y_velocity'] = \
                if 'z_velocity' not in entry['output']:
                    entry['output'][u'z_velocity'] = []
                    entry['legend_range'][u'z_velocity'] = \
            else:
                if 'x_velocity' in entry['output']:
                    entry['output'].pop(u'x_velocity')
                    entry['legend_range'].pop(u'x_velocity')
                if 'y_velocity' in entry['output']:
                    entry['output'].pop(u'y_velocity')
                    entry['legend_range'].pop(u'y_velocity')
                if 'z_velocity' in entry['output']:
                    entry['output'].pop(u'z_velocity')
                    entry['legend_range'].pop(u'z_velocity')
            entry['output'].pop(u'velocity')
            entry['legend_range'].pop(u'velocity')
        if 'mesh_displacement' in entry['output']:
                if 'x_mesh_displacement' not in entry['output']:
                    entry['output'][u'x_mesh_displacement'] = []
                    entry['legend_range'][u'x_mesh_displacement'] = \
                        entry['legend_range'][u'mesh_displacement']
                if 'y_mesh_displacement' not in entry['output']:
                    entry['output'][u'y_mesh_displacement'] = []
                    entry['legend_range'][u'y_mesh_displacement'] = \
                if 'z_mesh_displacement' not in entry['output']:
                    entry['output'][u'z_mesh_displacement'] = []
                    entry['legend_range'][u'z_mesh_displacement'] = \
            else:
                if 'x_mesh_displacement' in entry['output']:
                    entry['output'].pop(u'x_mesh_displacement')
                    entry['legend_range'].pop(u'x_mesh_displacement')
                if 'y_mesh_displacement' in entry['output']:
                    entry['output'].pop(u'y_mesh_displacement')
                    entry['legend_range'].pop(u'y_mesh_displacement')
                if 'z_mesh_displacement' in entry['output']:
                    entry['output'].pop(u'z_mesh_displacement')
                    entry['legend_range'].pop(u'z_mesh_displacement')
            entry['output'].pop(u'mesh_displacement')
            entry['legend_range'].pop(u'mesh_displacement')
        for output,outputArray in entry['output'].iteritems():
            if output not in othVarNms:
                print "given output %s not a valid output" % output
                continue
            arrayInd = which(coordDic, output)
            if arrayInd:
                outputVar   = output.split(arrayInd,1)[1]
                if outputVar != 'magnitude' and outputVar != 'viscosity':
                    index   = coordDic[arrayInd]
                    entry['output'][output] = numpy.asarray(
                      adb.getOthValues(entryName, 0, outputVar)[:,index])
                    continue
            scalarInd   = which( scalarVar, output )
            if scalarInd:
                outputVar   = output.split(scalarInd,1)[0]
                xValue      = numpy.asarray(
                            adb.getOthValues(entryName,0,outputVar)[:,0])
                yValue      = numpy.asarray(
                            adb.getOthValues(entryName,0,outputVar)[:,1])
                zValue      = numpy.asarray(
                            adb.getOthValues(entryName,0,outputVar)[:,2])
                value       = numpy.sqrt(
                            xValue**2 + yValue**2 + zValue**2           )
            else:
                value       = numpy.asarray(
                            adb.getOthValues( entryName, 0, output)[:,0])
            entry['output'][output]  = value
    # Add tables to the report
    Cd          = 0.0
    Cl          = 0.0
    Cc          = 0.0
    Ca          = 0.0
    global dataTable
    dataTable   = [ (   "Surface", "Drag Coefficient",
                        "Lift Coefficient", "Cross Coefficient" )   ]
    global fsiTable
    fsiTable    = [ (   "Surface", "Drag Coefficient",
                        "Lift Coefficient", "Cross Coefficient")    ]
        sName   = str(bdyPrt)
        sName   = string.replace( sName, "_", "\_" )
        dCoeff  = "%6.5f" % DragBodyAvg[bdyPrt]
        lCoeff  = "%6.5f" % LiftBodyAvg[bdyPrt]
        cCoeff  = "%6.5f" % CrossBodyAvg[bdyPrt]
        dataTable.append( ( sName, dCoeff, lCoeff, cCoeff ) )
        Cd      = Cd + DragBodyAvg[bdyPrt]
        Cl      = Cl + LiftBodyAvg[bdyPrt]
        Cc      = Cc + CrossBodyAvg[bdyPrt]
        sName   = str(whlPrt)
        dCoeff  = "%6.5f" % DragWheelAvg[whlPrt]
        lCoeff  = "%6.5f" % LiftWheelAvg[whlPrt]
        cCoeff  = "%6.5f" % CrossWheelAvg[whlPrt]
        Cd      = Cd + DragWheelAvg[whlPrt]
        Cl      = Cl + LiftWheelAvg[whlPrt]
        Cc      = Cc + CrossWheelAvg[whlPrt]
    for item in sorted(fsiPrts.iterkeys()):
        fCd = 0.0
        fCl = 0.0
        fCc = 0.0
        fCa = 0.0
            fCd = fCd + DragFsiAvg[fsiPrt]
            fCl = fCl + LiftFsiAvg[fsiPrt]
            fCc = fCc + CrossFsiAvg[fsiPrt]
            fCa = fCa + DragAreaFsiAvg[fsiPrt]
        sName   = (str(item)).replace(  "_" ,   " "     )
        fCd     = "%6.5f" % fCd
        fCl     = "%6.5f" % fCl
        fCc     = "%6.5f" % fCc
        fCa     = "%6.5f" % fCa
        fsiTable.append(  ( sName,  fCd,     fCl,    fCc     )  )
        sName   = str(prsPrt)
        if sName.endswith(' tri3 Fluid tet4'):
            sName = sName[:-16]
        dCoeff  = "%6.5f" % DragPorousAvg[prsPrt]
        lCoeff  = "%6.5f" % LiftPorousAvg[prsPrt]
        cCoeff  = "%6.5f" % CrossPorousAvg[prsPrt]
        Cd      = Cd + DragPorousAvg[prsPrt]
        Cl      = Cl + LiftPorousAvg[prsPrt]
        Cc      = Cc + CrossPorousAvg[prsPrt]
    dataTable.append( ( "Total ", Cd, Cl, Cc ) )
    global areaDataTable
    areaDataTable   = [ ( "Surface", "Drag Area" ) ]
        sName   = str(bdyPrt)
        aCoeff  = "%6.5f" % DragAreaBodyAvg[bdyPrt]
        areaDataTable.append( ( sName, aCoeff ) )
        Ca      = Ca + DragAreaBodyAvg[bdyPrt]
        sName   = str(whlPrt)
        aCoeff  = "%6.5f" % DragAreaWheelAvg[whlPrt]
        Ca      = Ca + DragAreaWheelAvg[whlPrt]
            sName   = str(fsiPrt)
            aCoeff  = "%6.5f" % DragAreaFsiAvg[fsiPrt]
        sName   = str(prsPrt)
            sName = sName[:-16]
        aCoeff  = "%6.5f" % DragAreaPorousAvg[prsPrt]
        Ca      = Ca + DragAreaPorousAvg[prsPrt]
    areaDataTable.append( ( "Total ", Ca ) )
    # Add curves to the report
    if sys.platform == "win32":
        lnTyp = "dotted"
    else:
        lnTyp = "solid"
    if 'simulationType' in parDic['ACS_GLOBAL']:
        if dict2Val(parDic['ACS_GLOBAL']['simulationType'])=='transient':
            xLabel  = "Time (s)"
            xTimes  = osiTimes
        else:
            xLabel  = "Iterations"
            xTimes  = osiSteps
    else:
        xTimes = osiSteps
    yLabel  = "Coefficients"
    crvList1= []
    curve1  = Curve(xTimes, TotDrag, name="Drag Coeff", color="Green",
                    lineType = lnTyp) #, symbol = "circle")
    crvList1.append( curve1 )
    curve2  = Curve(xTimes, TotLift, name="Lift Coeff", color="Red",
                    lineType = lnTyp) #, symbol = "square")
    crvList1.append( curve2 )
    curve3  = Curve(xTimes, TotCross, name="Cross Coeff", color="Blue",
                    lineType = lnTyp) #, symbol = "diamond")
    crvList1.append( curve3 )
    curve4  = Curve(xTimes, TotDragArea, name="Drag Area", color="Black",
    crvList1.append( curve4 )
    yMin    = -0.1
    yMax    = 0.5
    xMin    = xTimes[0]
    xMax    = xTimes[-1]
    if nSteps > 10:
        yMin    = min( TotDrag[10:,].min(),TotLift[10:,].min(),
                TotCross[10:,].min(),TotDragArea[10:,].min()) * 0.8
        yMax    = max( TotDrag[10:,].max(),TotLift[10:,].max(),
                TotCross[10:,].max(),TotDragArea[10:,].max()) * 1.2
        x_data                  = {}
        y_data                  = {}
        x_data['all']           = xTimes
        y_data['Drag Coeff']    = TotDrag
        y_data['Lift Coeff']    = TotLift
        y_data['Cross Coeff']   = TotCross
        y_data['Drag Area']     = TotDragArea
        fvPlots                 = AcuPlot()
        fvPlots.addPlot(x_data  = x_data,       y_data  = y_data,
                        x_label = xLabel,       y_label = yLabel,
                        title   = "Drag Plots", xRange  = (xMin, xMax),
                        yRange  = (yMin, yMax))
        if len(othDir) != 0:
            for entry in othDir:
                for output in othDir[entry]['output']:
                    try:
                        yMin = othDir[entry]['legend_range'][output][0]
                        yMax = othDir[entry]['legend_range'][output][1]
                    except:
                        yMin = 'Auto'
                        yMax = 'Auto'
                    if yMin == 'Auto':
                        try:
                            yMin = othDir[entry]['output'][output].min()
                        except:
                            yMin = min(othDir[entry]['output'][output])
                    else:
                        yMin = float(yMin)
                    if yMax == 'Auto':
                        try:
                            yMax = othDir[entry]['output'][output].max()
                        except:
                            yMax = max(othDir[entry]['output'][output])
                    else:
                        yMax = float(yMax)
                    fvPlots.addPlot(
                        x_data  = x_data,
                        y_data  = {output:othDir[entry]['output'][output]},
                        x_label = xLabel,
                        y_label = output,
                        title   = '%s_%s' % ( entry, output ),
                        yRange  = (yMin, yMax) )
        fvPlots.createPlots()
    else:
        global plot1
        plot1   = Plot2D(crvList1,  width = 800,height  =   600,
                        xLabel  =   xLabel,     yLabel  =   yLabel,
                        yRange  =   [yMin,yMax],gridFlag=   True )
                    try:
                    except:
                        yMin = 'Auto'
                        yMax = 'Auto'
                    if yMin == 'Auto':
                        try:
                        except:
                    else:
                        yMin = float(yMin)
                    if yMax == 'Auto':
                        try:
                        except:
                    else:
                        yMax = float(yMax)
                    crvls = []
                    crvnm = '%s_%s' % (entry, output)
                    crvnm = crvnm.replace(' ', '_')
                    curvv = Curve(xTimes, othDir[entry]['output'][output],
                                  name = crvnm, color = "Red",
                    crvls.append( curvv )
                    curfn = 'Figures/%s' % crvnm
                    optDir[crvnm] = Plot2D(
                                crvls, width = 800, height = 600,
                                xLabel = xLabel, yLabel = output,
                                xRange = [xMin, xMax],
                                yRange = [yMin, yMax], gridFlag = True,
                                fileName = curfn)
    fsiFlag = False
                fsiFlag = True
    return
    if not fsiFlag:
        return
    # MESH DISPLACEMENTS - already return called
    colortable      = [ 'Green', 'Red', 'Blue', 'Yellow', 'Black' ]
    colortable      = colortable + colortable
    #symboltable     = [ 'circle', 'square']
    #for i in range(8):
        #symboltable.append('diamond')
    xDisplacements  = []
    yDisplacements  = []
    zDisplacements  = []
    for item,ind in zip( sorted( fsiPrts.iterkeys() ),
      range( len( fsiPrts ) ) ):
        tmpCrv      = Curve(xTimes,
                            MeshXDisplacement[item],
                            name    = "mesh_x_displacement " + item,
                            color   = colortable[ind],
                            lineType= lnTyp,
                            #symbol  = symboltable[ind]
        xDisplacements.append( tmpCrv )
                            MeshYDisplacement[item],
                            name    ="mesh_y_displacement " + item,
                            color   =colortable[ind],
                            lineType= lnTyp,
        yDisplacements.append( tmpCrv )
                            MeshZDisplacement[item],
                            name    ="mesh_z_displacement " + item,
                            lineType= lnTyp,
        zDisplacements.append( tmpCrv )
    ### x displacement plot
    yMin        = 1000
    yMax        = -1000
    for item in MeshXDisplacement:
        yMin    = min( yMin, MeshXDisplacement[item].min() )
        yMax    = max( yMax, MeshXDisplacement[item].max() )
    yLabel      = "mesh_x_displacement in [m]"
    plotX       = Plot2D(
                        xDisplacements,     width   = 800,  height = 600,
                        yRange  = [ yMin * 0.8 , yMax * 1.2 ],
                        gridFlag= True
    ### y displacement plot
    yMin        = 1000
    yMax        = -1000
    for item in MeshYDisplacement:
        yMin    = min( yMin, MeshYDisplacement[item].min() )
        yMax    = max( yMax, MeshYDisplacement[item].max() )
    yLabel      = "mesh_y_displacement in [m]"
    plotY       = Plot2D(
                        yDisplacements,     width   = 800,  height = 600,
                        gridFlag= True
    ### z displacement plot
    yMin        = 1000
    yMax        = -1000
    for item in MeshZDisplacement:
        yMin    = min( yMin, MeshZDisplacement[item].min() )
        yMax    = max( yMax, MeshZDisplacement[item].max() )
    yLabel      = "mesh_z_displacement in [m]"
    plotZ       = Plot2D(
                        zDisplacements,     width   = 800,  height = 600,
                        gridFlag= True                                  )
    rep.beginBullet()
    rep.addItem("The mesh displacement in x-direction for the different"\
                " FSI components is plotted in Figure"\
                " \\ref{fig:xDisplacements}.", name = ""                )
    rep.endBullet()
    rep.addFigure(  plotX, "center", "x-displacement",
                    1.0/imgFct, ref="fig:xDisplacements"                )
    rep.beginBullet()
    rep.addItem("The mesh displacement in y-direction for the different"\
                " \\ref{fig:yDisplacements}.", name = ""                )
    rep.endBullet()
    rep.addFigure(  plotY, "center", "y-displacement",
                    1.0/imgFct, ref="fig:yDisplacements"                )
    rep.beginBullet()
    rep.addItem("The mesh displacement in z-direction for the different"\
                " \\ref{fig:zDisplacements}.", name = ""                )
    rep.endBullet()
    rep.addFigure(  plotZ, "center", "z-displacement",
                    1.0/imgFct, ref="fig:zDisplacements"                )
# Residual and Solution ratio
def createResidualSolutionRatios( rep, adb ):
    #tStp   = adb.getSteps()
    timeSecs= adb.get('times')
    pressure=  adb.getResRatioData( "pressure", type = "final" )
    eddy    =  adb.getResRatioData( "eddy-viscosity", type = "final" )
    velocity=  adb.getResRatioData( "velocity", type = "final" )
    pTim    = pressure[1]
    vTim    = velocity[1]
    eTim    = eddy[1]
    pRes    = pressure[2]
    vRes    = velocity[2]
    eRes    = eddy[2]
    if len(pTim) != len(pRes):
        pRes = pRes[:len(pRes)-1]
        vRes = vRes[:len(vRes)-1]
        eRes = eRes[:len(eRes)-1]
        lnTyp = "dotted"
    else:
        lnTyp = "solid"
    curve1  = Curve( pTim, pRes, name = "Pressure", color = "blue",
                     symbol="circle", lineType = lnTyp )
    curve2  = Curve( vTim, vRes, name = "Velocity", color = "red",
                     symbol="square", lineType = lnTyp )
    curve3  = Curve( eTim, eRes, name = "Eddy Viscosity", color = "green",
                     symbol="diamond", lineType = lnTyp )
    rcrvList= []
    rcrvList.append( curve1 )
    rcrvList.append( curve2 )
    rcrvList.append( curve3 )
    fname   = Plot2D(rcrvList,                  width   =1200,
                    height  =800,               resScale= 2,
                    xLabel  = "Time (s)",       yLog    = True,
                    yLabel  = "Residual Ratio", gridFlag= True,
                    fileName= "resratio",       fileType= "png" )
    pressure=  adb.getSolRatioData( "pressure", type = "final" )
    eddy    =  adb.getSolRatioData( "eddy-viscosity", type = "final" )
    velocity=  adb.getSolRatioData( "velocity", type = "final" )
    pTim    = pressure[1]
    vTim    = velocity[1]
    eTim    = eddy[1]
    pSol    = pressure[2]
    vSol    = velocity[2]
    eSol    = eddy[2]
    if len(pTim) != len(pSol):
        pSol= pSol[:len(pSol)-1]
        vSol= vSol[:len(vSol)-1]
        eSol= eSol[:len(eSol)-1]
    curve4  = Curve( pTim, pSol, name = "Pressure", color = "blue",
    curve5  = Curve( vTim, vSol, name = "Velocity", color = "red",
                     symbol="square" , lineType = lnTyp )
    curve6  = Curve( eTim, eSol, name = "Eddy Viscosity", color = "green",
                     symbol="diamond" , lineType = lnTyp )
    scrvList= []
    scrvList.append( curve4 )
    scrvList.append( curve5 )
    scrvList.append( curve6 )
    fname   = Plot2D(scrvList, width   =1200,   height  =800,
                    resScale= 2,
                    yLabel  = "Solution Ratio", gridFlag= True,
                    fileName= "solratio",       fileType= "png" )
    pass
# animation
def createVideo( lZeros ):
    homeDir     = os.getenv(    'ACUSIM_HOME', 'none'       )
    verDir      = os.getenv(    'ACUSIM_VERSION', 'none'    )
    machineDir  = os.getenv(    'ACUSIM_MACHINE', 'none'    )
    acuDir      = os.path.join( homeDir , machineDir        )
                                os.path.join( acuDir, 'base'),
                                'ImageMagick'               )
        vidExec     = os.path.join(     acuDir, 'ffmpeg'    )
    else:
                                'bin'               )
    os.chdir('Animation')
    extension   = ( "%%0%dd" % lZeros ) % 1
    testBase    = glob.glob(    '*_%s.*' % extension          )
    if not testBase:
        print "no files to convert"
        os.chdir('..')
        return
    ext         = testBase[0].rsplit('.')[-1]
    for ind,item in enumerate(testBase):
        testBase[ind]   = item.split('_%s.' % extension)[0]
    nOutputs    = len( glob.glob( testBase[0] + '*' )       )
    if nOutputs >= 50:
        frate   = 15
    elif nOutputs >= 10:
        frate   = 7
    else:
        frate   = 1
    for base in testBase:
        vidCmd  = [ vidExec, '-f', 'image2', '-r', '%d' % frate, '-i',
                    '%s_%%0%dd.%s' % (base, lZeros , ext),
                    '-vcodec','copy', '-y', '%s.mp4' % base             ]
        proc = subprocess.Popen(vidCmd , stdout=subprocess.PIPE,
                                stderr=subprocess.PIPE                  )
        proc.wait()
    os.chdir('..')
# Images
def createImages(   rep, compMap, parDic, fsiDic,
                    fDir=0, tDir=1, cDir=2, rho=1.225
    print "enter images"
    if 'flow_direction' in parDic['ACS_GLOBAL']:
        fDir    = dict2Val( parDic['ACS_GLOBAL']['flow_direction']  )
    if 'top_direction' in parDic['ACS_GLOBAL']:
        tDir    = dict2Val( parDic['ACS_GLOBAL']['top_direction']   )
    if 'cross_direction' in parDic['ACS_GLOBAL']:
        cDir    = dict2Val( parDic['ACS_GLOBAL']['cross_direction'] )
    cbbox           = (0.0,1.0,0.0,1.0,0.0,1.0)
    tbbox           = (-1.0,6.0,-2.0,2.0,0.0,4.0)
    fsiBbox         = {}
    angle_axis_from = (4.0,0.7,-4.0)
    Vin             = 1.0
    if "angle_axis_from" in parDic['ACS_GLOBAL']:
        angle_axis_from = dict2Val(
                                parDic['ACS_GLOBAL']['angle_axis_from'] )
    if "zoom" in parDic['ACS_GLOBAL']:
        zoom    = dict2Val( parDic['ACS_GLOBAL']['zoom'] )
    if "inletVelocity" in parDic['ACS_GLOBAL']:
        Vin     = dict2Val( parDic['ACS_GLOBAL']['inletVelocity'] )
    if "body_bounding_box" in parDic['ACS_GLOBAL']:
        cbbox   = dict2Val( parDic['ACS_GLOBAL']['body_bounding_box'] )
    if "tunnel_bounding_box" in parDic['ACS_GLOBAL']:
        tbbox   = dict2Val( parDic['ACS_GLOBAL']['tunnel_bounding_box'] )
            fsiBbox[comp]= dict2Val(
                    parDic['ACS_FLEXIBLE_BODIES'][comp]['bounding_box'] )
    ( Bx1, Bx2, By1, By2, Bz1, Bz2 ) = cbbox
    Bxa = 0.5 * ( Bx1+Bx2 )
    Bya = 0.5 * ( By1+By2 )
    Bza = 0.5 * ( Bz1+Bz2 )
    ( Tx1, Tx2, Ty1, Ty2, Tz1, Tz2 ) = tbbox
    Txa = 0.5 * ( Tx1+Tx2 )
    Tya = 0.5 * ( Ty1+Ty2 )
    Tza = 0.5 * ( Tz1+Tz2 )
    if tDir == 1:
        axis_up = (0,1,0)
    elif tDir == 2:
        axis_up = (0,0,1)
    elif tDir == 0:
        axis_up = (1,0,0)
    if fDir == 0:
        Bxf = Bx1
        Tyf = Ty1
        if tDir == 1:
            Byf = By2
            Bzf = Bz1
            Tyf = Ty2
            Tzf = Tz1
        if tDir == 2:
            Bzf = Bz2
            Byf = By1
            Tzf = Tz2
            Tyf = Ty1
    bdyType     = []
    botType     = []
    fsiType     = {}
            fsiType[comp] = []
                fsiType[comp].append( "OSF: %s" % str(item) )
    inType      = []
    prsType     = []
                ikey    = dict2Val(
                if (ikey.find( 'WHEEL' )!= -1 \
                 or ikey.find( 'BODY' ) != -1 \
                 or ikey.find( 'flex' ) != -1 ):
                    bdyStr  = "OSF: %s" % str(comp)
                    bdyType.append( bdyStr )
                if ikey.find( 'WT_BOTTOM' ) != -1:
                    botStr  = "SBC: %s" % str(comp)
                    botType.append( botStr )
                if ikey.find( 'WT_INLET' ) != -1:
                    inStr   = "SBC: %s" % str(comp)
                    inType.append( inStr )
                if ikey.find('POROUS') != -1:
                    prsStr  = "OSF: %s tri3 Fluid tet4" % str(comp)
                    prsType.append( prsStr )
                    bdyType.append( prsStr )
            else:
                    srfout = dict2Val(
                    if not srfout:
                    else:
    botTup = tuple( botType )
    bdyTup = tuple( bdyType )
    inTup  = tuple( inType )
    prsTup = tuple( prsType )
    ###create fsi view factors
    fsiView     = {}
    fsiSideL    = {}
    fsiSideR    = {}
    fsiTop      = {}
    for bc in fsiType:
        fsiView[bc]                     = {}
        ( fx1, fx2, fy1, fy2, fz1, fz2 )= fsiBbox[bc]
        c1, c2, c3  = (fx1+fx2)/2, (fy1+fy2)/2, (fz1+fz2)/2
        center      = "%6.3f %6.3f %6.3f" % ( c1, c2, c3 )
        zoomArr     = [ fx2-fx1, fy2-fy1, fz2-fz1 ]
        zoomArr.sort()
        zoomFsi     = zoomArr[2]/zoomArr[0]
        zoomFsi     = zoomFsi * 10
        if tDir == 2:
            fTopY   = c2
            fTopZ   = fz2 + zoomArr[2]
            fLeftY  = fy1 - zoomArr[2]
            fLeftZ  = c3
            fRightY = fy2 + zoomArr[2]
            fRightZ = c3
            ## check if flexible component is
            ## left or right of the body center
            if (Bya - fy1 ) >= 0:
                lf1, lf2, lf3   = \
                    c1 - zoomArr[2], c2 - zoomArr[2], c3 + zoomArr[2] / 2
            else:
                lf1, lf2, lf3   = \
                    c1 - zoomArr[2], c2 + zoomArr[2], c3 + zoomArr[2] / 2
        else:
            fTopY   = fy2 + zoomArr[2]
            fTopZ   = c3
            fLeftY  = c2
            fLeftZ  = fz1 - zoomArr[2]
            fRightY = c2
            fRightZ = fz2 + zoomArr[2]
            if (Bza - fz2) >= 0:
                lf1, lf2, lf3   = \
                    c1 - zoomArr[2], c2 + zoomArr[2], c3 - zoomArr[2] / 2
            else:
                lf1, lf2, lf3   = \
        fsiView[bc]['axis_from']            = ( lf1, lf2, lf3 )
        fsiView[bc]['axis_at']              = ( c1, c2, c3 )
        fsiView[bc]['axis_up']              = axis_up
        fsiView[bc]['center']               = center
        fsiView[bc]['zoom']                 = zoomFsi
        fsiView[bc]['outline']              = "off"
        fsiSideL[bc]                        = copy.copy( fsiView[bc] )
        fsiSideL[bc]['axis_from']           = ( c1, fLeftY, fLeftZ   )
        fsiSideR[bc]                        = copy.copy( fsiView[bc] )
        fsiSideR[bc]['axis_from']           = ( c1, fRightY, fRightZ )
        fsiTop[bc]                          = copy.copy( fsiView[bc] )
        fsiTop[bc]['axis_from']             = ( c1, fTopY, fTopZ     )
    ###  ANIMATION ###
    if 'animation' in parDic['ACS_GLOBAL']:
        animation = dict2Val(parDic['ACS_GLOBAL']['animation'])
        digits  = -1
    else:
        animation = False
    if animation: #if animation == 'True':
        print "enter animation"
        try:
            os.mkdir('Animation')
        except:
            pass
        nSteps          = adb.get(  'nSteps'    )
        if 'outputFrequency' in parDic['ACS_GLOBAL']:
            outputFreq  = dict2Val(
                                parDic['ACS_GLOBAL']['outputFrequency'] )
        if 'saved_states' in parDic['ACS_GLOBAL']:
            nSavedStates= dict2Val( parDic['ACS_GLOBAL']['saved_states'])
        startTimeStep   = nSteps - (nSavedStates - 1) * outputFreq
        center              = "%6.3f %6.3f %6.3f" % (Bxa + (Bx2-Bxa)/2,
                                                     Bya, Bz2 + Bz2     )
        sideView                = {}
        sideView['axis_at']     = ( Bxa, Bya, Bza )
        sideView['axis_from']   = ( Bxa, Byf, Bza )
        sideView['center']      = center
        sideView['zoom']        = (Bx2 - Bx1) / (Bz2 - Bz1) * 2
        fvxObj              = AcuFvx(   logFile = "./%s" % logFile,
                                        transient="on",
                                        transStart = startTimeStep,
                                        fvxFile = fvxFile               )
        fvxObj.writeVerbatim(text   = 'fv_script("SIZE 640 360")'   )
        fvxObj.setBackground(color  = "white" )
        fvxObj.addViewTable(name            = "view_table_1",
                            zoom            = sideView['zoom'],
                            angle_axis_at   = sideView['axis_at'],
                            angle_axis_up   = axis_up,
                            angle_axis_from = sideView['axis_from'],
                            axis_markers    = "on",
                            outline         = "off",)
        fvxObj.writeViewTable( "view_table_1" )
        tmpdic ={'center':sideView['center']}
        fvxObj.modifyView(  name = "view_table_1",
                            dTable = {'center':sideView['center']}      )
        fvxObj.addBndSrf(   "bnd_surf_bdy",
                            types       = bdyTup,
                            show_mesh   ="off",
                            scalar_func ="none",
                            transparency= 0.0                           )
        fvxObj.writeBndSrf( "bnd_surf_bdy" )
        fvxObj.addCrdSrf(   name            = "crd_surf_y",
                            axis            = "Y",
                            y_axis_current  = Bya,
                            scalar_func     = "velocity_magnitude"      )
        fvxObj.writeCrdSrf( name = "crd_surf_y" )
        fvxObj.createDisplacementFormula( name="vwtDisplacement" )
        for bc in fsiType:
            bndName = "bnd_surf_fsi_%s" % str(bc)
            crdName = "crd_surf_fsi_%s" % str(bc)
            fsiTup  = tuple( fsiType[bc] )
            fvxObj.addBndSrf(   bndName,
                                types       = fsiTup,
                                show_mesh   ="off",
                                scalar_func ="vwtDisplacement",
                                transparency= 0.0,
                                visibility  ="off"                      )
            fvxObj.writeBndSrf( bndName )
            fvxObj.addCrdSrf(   name            = crdName,
                                axis            = "Y",
                                y_axis_current  = c2,
                                scalar_func     = "velocity_magnitude",
                                transparency    = 0.2,
                                visibility      = "off"                 )
            fvxObj.writeCrdSrf( crdName )
        ## go through transient loop and create images
        counter = 0
        digits  = len( str(( nSteps - startTimeStep ) / outputFreq + 1 ))
        for ts in range( startTimeStep, nSteps + 1, outputFreq ):
            counter     = counter + 1
            strCounter  = ("%%0%dd" % digits) % counter
                    text = "set_transient( {time_step = %d},1 )" % ts   )
            ## get handles and turn off all configurations
            fvxObj.updateHdls()
            ##select views
            # side view
            fvxObj.modifyView( name = "view_table_1", dTable = sideView )
                        'modify(boundary_surface_0,{transparency=0.0})' )
            fvxObj.setVis(  name        = "crd_surf_y",
                            dataType    = 'crdSrf',
                            visibility  = True                          )
            fvxObj.setCrdLeg( name      = "crd_surf_y"                  )
            fvxObj.saveImage(
                fileName  = "Animation/body_section_%s.jpg" % strCounter)
            #fvxObj.updateHdls()
            # fsi views
                        'modify(boundary_surface_0,{transparency=0.5})' )
                            visibility  = False                         )
            for bc in fsiType:
                                    dTable  = fsiView[bc]               )
                fvxObj.writeVerbatim( '-- view modified')
                fvxObj.setVis(      name        = bndName,
                                    dataType    = 'bndSrf',
                                    visibility  = True                  )
                    'modify(%s,{scalar_func="vwtDisplacement"})' \
                    % fvxObj.bndHdl[bndName]                            )
                fvxObj.setBndLeg(   name    = bndName                   )
                fvxObj.saveImage(
                    fileName = "Animation/fsi_displacement_%s_%s.jpg" % \
                                                ( str(bc), strCounter ) )
                    'modify(%s,{scalar_func="pressure"})' % \
                fvxObj.saveImage(
                    fileName = "Animation/fsi_pressure_%s_%s.jpg" % \
                    (str(bc),strCounter)                                )
                    'modify(%s,{scalar_func="none"})' % \
                fvxObj.setVis(  name        = crdName,
                                visibility  = True                      )
                fvxObj.setBndLeg(   name      = bndName, on   =   False )
                fvxObj.setCrdLeg(   name      = crdName )
                fvxObj.saveImage(
                        fileName = "Animation/fsi_section_%s_%s.jpg" % \
                fvxObj.setCrdLeg(   name    = crdName,  on  =   False   )
    else:
                            transient   = "off",
                            fvxFile     = fvxFile                       )
        fvxObj.writeVerbatim(   text    = 'fv_script("SIZE 640 360")'   )
        fvxObj.setBackground(   color   = "white"                       )
    size    = len( fvxObj.bndSrf )
    for i in range( size ):
        fvxObj.writeVerbatim( 'all_handles = get_all_object_handles(1)' )
                'tmp_hdl = all_handles.boundary_handles[%d]'% (size - i))
        fvxObj.writeVerbatim(           'delete( tmp_hdl )'             )
    tmpList = []
    for item in fvxObj.bndSrf:
        tmpList.append( item )
    for item in tmpList:
        fvxObj.writeDelBndSrf( name = item )
    size    = len( fvxObj.crdSrf )
                'tmp_hdl = all_handles.coord_handles[%d]'% (size - i)   )
        fvxObj.writeVerbatim(           'delete(tmp_hdl)'               )
    tmpList = []
    for item in fvxObj.crdSrf:
        fvxObj.writeDelCrdSrf( name = item )
    axis_at     = ( Bxa, Bya, Bza )
    axis_from   = ( Bxf, Byf, Bzf )
    zoomSort    = [ Tx2-Tx1, Ty2-Ty1, Tz2-Tz1 ]
    zoomSort.sort()
    zoom        = 0.75*zoomSort[2]/zoomSort[1]
    #fvxObj= AcuFvx(    logFile     = "./%s" % logFile,
    #                   transient   = "off",
    #                   fvxFile     = fvxFile                           )
    #fvxObj.writeVerbatim(  text    = 'fv_script("SIZE 640 360")'       )
    #fvxObj.setBackground(  color   = "white"                           )
                        zoom            = zoom,
                        angle_axis_at   = axis_at,
                        angle_axis_from = axis_from,
                        outline         = "on",                         )
    center = "%6.3f %6.3f %6.3f" % (    Txa, Tya, Tza                   )
    fvxObj.writeVerbatim(       text='fv_script("CENTER %s")'% center   )
                        types       = bdyTup,
                        show_mesh   = "off",
                        scalar_func = "none",
                        transparency= 0.0                               )
    fvxObj.addBndSrf(   "bnd_surf_bot",
                        types       = botTup,
                        show_mesh   = "off",
                        transparency= 0.5                               )
    fvxObj.writeBndSrf( "bnd_surf_bot"                                  )
    fvxObj.saveImage(   fileName    = "tun_bdy_vew.jpg"                 )
    zoom = 2 * ( Tx2 - Tx1 ) / ( Bx2 - Bx1 )
    fvxObj.writeVerbatim(   "view_table_1.zoom=%f"%zoom)
    fvxObj.writeVerbatim(   text    = 'view_table_1.outline="off"'      )
    fvxObj.writeVerbatim(   text    = 'set_view( view_table_1)'         )
    center = "%6.3f %6.3f %6.3f" % ( Bxa, Bya, Bza )
    fvxObj.writeVerbatim(   text    = 'fv_script("CENTER %s")'% center  )
                text = 'modify(boundary_surface_1,{visibility="off"})'  )
                text = 'modify(boundary_surface_0,{scalar_func="none"})')
    fvxObj.saveImage(       fileName = "wnd_tun_log.jpg"                )
    fvxObj.writeVerbatim(   text = \
        'modify(boundary_surface_0,{scalar_func="none",show_mesh="on"})')
    fvxObj.saveImage(       fileName= "bod_msh.jpg"  )
        'modify(boundary_surface_0,{scalar_func="pressure",'\
        'show_mesh="off"})'                                             )
                    text = 'set_legend("1","0.95","0.85","BOUNDARY",1)' )
    fvxObj.saveImage(       fileName = "bnd_press.jpg"                  )
                    text = 'handle_table = get_all_object_handles(1)'   )
        text = 'boundary_handle_0 = handle_table.boundary_handles[1]'   )
        text = 'boundary_handle_1 = handle_table.boundary_handles[2]'   )
    if 'inletVelocity' in parDic['ACS_GLOBAL']:
    fvxObj.createCpFormula( name    = "vwtCp",
                            velocity= Vin,
                            density = rho                               )
    fvxObj.addCrdSrf(   "coord_surf_1",
                        show_mesh       = "off",
                        scalar_func     = "vwtCp",
                        axis            = 'X',
                        x_axis_current  = Bx2 + Bxa / 2                 )
    fvxObj.writeCrdSrf( "coord_surf_1")
                text = 'modify(coordinate_surface_0,{visibility="off"})')
                text = 'modify(boundary_handle_0,{scalar_func="vwtCp"})')
    fvxObj.saveImage(   fileName = "coord_press.jpg"                    )
    lookat = "{%6.3f,%6.3f,%6.3f,}" % ( Bxa, Bya, Bza )
    if cDir == 1:
        fvxObj.addCrdSrf(   "coord_surf_2",
                            show_mesh       = "on",
                            axis            = 'Y',
                            y_axis_current  = Bya                       )
        lookfrom= "{%6.3f,%6.3f,%6.3f,}" % (    Bxa, Byf, Bza           )
        center  = "%6.3f %6.3f %6.3f" % (       Bxa, Bya, Bz2           )
    elif cDir == 2:
                            show_mesh       = "on",
                            axis            = 'Z',
                            z_axis_current  = Bza                       )
        lookfrom= "{%6.3f,%6.3f,%6.3f,}" % ( Bxa, Bya, Bzf )
        center  = "%6.3f %6.3f %6.3f" % ( Bxa, By2, Bza )
    else:
                            show_mesh       = "on",
                            axis            = 'X',
                            x_axis_current  = Bxa                       )
        lookfrom= "{%6.3f,%6.3f,%6.3f,}" % ( Bx2, Bya, Bza )
        center  = "%6.3f %6.3f %6.3f" % ( Bx2, Bya, Bza )
    fvxObj.writeVerbatim(   "view_table_1.angle_axis.from=%s" % lookfrom)
    fvxObj.writeVerbatim(   "view_table_1.angle_axis.at=%s" % lookat    )
    fvxObj.writeVerbatim(   text = 'fv_script("CENTER %s")' % center    )
    fvxObj.writeCrdSrf(     "coord_surf_2"                              )
                text = 'modify(boundary_handle_0,{scalar_func="none"})' )
    fvxObj.saveImage(       fileName = "coord_mesh.jpg"                 )
            text = 'modify(boundary_handle_0,{scalar_func="pressure"})' )
            text = 'modify(coordinate_surface_1,{show_mesh="off"})'     )
        text = 'modify(coordinate_surface_1,{scalar_func="pressure"})'  )
    #fvxObj.saveImage(  fileName = "coord_press.jpg"                    )
    zoomStr = "%d" % (zoom*0.75)
    fvxObj.writeVerbatim(   "view_table_1.zoom = %s" % zoomStr          )
    centerEnd = "%6.3f %6.3f %6.3f" % ( Bx2, Bya, Bza )
    fvxObj.writeVerbatim(   text = 'fv_script("CENTER %s")'% centerEnd  )
    fvxObj.saveImage(   fileName = "coord_press22.jpg"                  )
      'modify(coordinate_surface_1,{scalar_func="velocity_magnitude"})' )
    zoomStr = "%d" % zoom
                        text = 'set_legend("1","0.95","0.85","COORD",2)')
    fvxObj.saveImage(       fileName= "coord_velocity.jpg"              )
        text = 'coordinate_handle_1 = handle_table.coord_handles[2]'    )
                text = 'modify(coordinate_handle_1,{visibility="off"})' )
    if fDir == 0:
        xC  = Bxa
        fvxObj.writeVerbatim( "view_table_1.angle_axis.from=%s"%lookfrom)
        if tDir == 1:
        if tDir == 2:
        fvxObj.addCrdSrf(   "coord_surf_3",
                            show_mesh       = "on",
                            axis            = 'X',
                            x_axis_current  = xC                        )
        fvxObj.writeCrdSrf( "coord_surf_3")
        fvxObj.saveImage(   fileName        = "coord_mesh2.jpg"         )
            text = 'modify(coordinate_surface_2, {show_mesh="off"})'    )
            'modify(coordinate_surface_2, {scalar_func="pressure"})'    )
        fvxObj.saveImage(       fileName = "coord_press2.jpg"           )
        text = 'modify(coordinate_surface_2,{visibility="off"})'        )
    if cDir == 1:
        axis_up = "{%d,%d,%d,}" % (0,1,0)
        fvxObj.addCrdSrf(   "coord_surf_4",
                            show_mesh       = "off",
                            axis            = 'Z',
                            z_axis_current  = Bza,
    if cDir == 2:
        axis_up = "{%d,%d,%d,}" % (0,0,1)
                            show_mesh       = "off",
                            axis            = 'Y',
    fvxObj.writeVerbatim(   "view_table_1.angle_axis.up=%s" % axis_up   )
    fvxObj.writeCrdSrf(     "coord_surf_4" )
                        text = 'set_legend("1","0.95","0.85","COORD",4)')
    fvxObj.saveImage(       fileName = "coord_velocity2.jpg"            )
        text =' coordinate_handle_3 = handle_table.coord_handles[4]'    )
                text = 'modify(coordinate_handle_3,{visibility="off"})' )
     'modify(boundary_handle_0,{scalar_func="none", transparency =0.5})')
    bndIndex                = len( fvxObj.bndHdl )
    for bc in fsiType:
                            types       = fsiTup,
                            show_mesh   = "off",
                            scalar_func = "surface_y_plus",
                            transparency= 0.0,
                            visibility  = "on"                          )
        fsiView[bc]['zoom'] = fsiView[bc]['zoom'] * 2
        fvxObj.modifyView(  name = "view_table_1", dTable = fsiView[bc] )
        fvxObj.saveImage(   fileName = "y_plus_flex_%s.jpg" % str(bc)   )
        fvxObj.modifyView( name = "view_table_1", dTable = fsiSideR[bc] )
        fvxObj.saveImage( fileName = "y_plus_side_flex_%s.jpg" % str(bc))
        fvxObj.modifyView( name = "view_table_1", dTable = fsiTop[bc]   )
        fvxObj.saveImage( fileName = "y_plus_top_flex_%s.jpg" % str(bc) )
        text = 'coordinate_handle_3 = handle_table.coord_handles[4]'    )
        text = 'modify(boundary_handle_0,{transparency=0.0})'           )
        text = 'view_table_1.zoom = %s' % zoomStr                       )
    seedX = []
    seedY = []
    seedZ = []
    if tDir == 1:
        I = 10
        J = 6
    if tDir == 2:
        I = 6
        J = 10
    for i in range(0, I):
        for j in range(0, J):
            seedX.append(Tx1+0.01*(Tx2-Tx1))
            seedY.append(By2-i*(By2-By1)/10)
            seedZ.append(Bz2-j*(Bz2-Bz1)/10)
    seedingX = "%s" % seedX
    seedingY = "%s" % seedY
    seedingZ = "%s" % seedZ
    seedingX = '{'+seedingX.strip('[]')+'}'
    seedingY = '{'+seedingY.strip('[]')+'}'
    seedingZ = '{'+seedingZ.strip('[]')+'}'
    fvxObj.addStrmLn(   "strm_ln_0",
                        calculation_parameters_direction        = "both",
                        calculation_parameters_step             = 5,
                        calculation_parameters_time_limit       = 2,
                        calculation_parameters_release_interval = 3,
                        calculation_parameters_duration         = 1,
                        visibility      = "on",
                        display_seeds   = "off",
                        vector_func     = "velocity",
                        mode            = "add",
                        seed_coord      = "XYZ",
                        x               = seedingX,
                        y               = seedingY,
                        z               = seedingZ)
    fvxObj.writeStrmLn( "strm_ln_0" )
    if tDir == 1:
    if tDir == 2:
    lookfrom= "{%6.3f,%6.3f,%6.3f,}" % ( Bxf, Byf, Bzf )
    fvxObj.writeVerbatim( "view_table_1.angle_axis.from=%s" % lookfrom  )
        text = 'set_legend("1","0.95","0.85","STREAM",1)'               )
    fvxObj.saveImage(   fileName = "stream_lines_1.jpg"                 )
    if fDir == 0:
        if tDir == 1:
        if tDir == 2:
        fvxObj.saveImage(   fileName= "stream_lines_2.jpg"              )
    #fvxObj.writeVerbatim( text= 'modify(strm_ln_0,{visibility="off"})' )
        text = 'strm_ln_handle_0 = handle_table.streamline_handles[1]'  )
        text = 'modify(strm_ln_handle_0,{visibility="off"})'            )
        text = 'modify(boundary_handle_0,{scalar_func="surface_y_plus"})')
    if tDir == 1:
    if tDir == 2:
    fvxObj.saveImage( fileName  = "body_y_plus_front.jpg"               )
    if fDir == 0:
        if tDir == 1:
        if tDir == 2:
        fvxObj.saveImage( fileName = "body_y_plus_back.jpg"             )
    if fDir == 0:
        if tDir == 1:
            axis_up = "{%d,%d,%d,}" % (1,0,0)
            lookfrom= "{%6.3f,%6.3f,%6.3f,}" % ( Bxa, By1, Bza )
        if tDir == 2:
            lookfrom= "{%6.3f,%6.3f,%6.3f,}" % ( Bxa, Bya, Bz1 )
        fvxObj.saveImage( fileName  = "body_y_plus_bottom.jpg"          )
    zoom = 2*(Tx2-Tx1)/(Bx2-Bx1)
    fvxObj.writeVerbatim(           "view_table_1.zoom=%f" % zoom       )
    fvxObj.writeVerbatim(       text = 'fv_script("CENTER %s")' % center)
    sVarDic = { 'x_velocity':'x-velocity',
                'y_velocity':'y-velocity',
                'z_velocity':'z-velocity',
                'x_mesh_displacement':'x-mesh_displacement',
                'y_mesh_displacement':'y-mesh_displacement',
                'z_mesh_displacement':'z-mesh_displacement'         }
    allVars = [ 'pressure', 'velocity', 'velocity_magnitude',
                'mesh_displacement', 'eddy_viscosity', 'x_velocity',
                'y_velocity', 'z_velocity', 'x_mesh_displacement',
    fsiFlag = False
            fsiFlag = True
    if 'ACS_BOUNDARY_SURFACES' in parDic:
        for bndSrf in parDic['ACS_BOUNDARY_SURFACES']:
            surfaces    = dict2Val(
                    parDic['ACS_BOUNDARY_SURFACES'][bndSrf]['surfaces'] )
            types       = '{ '
            for srf in surfaces:
                types   = types + '"OSF: %s",' % srf
            types       = types + ' }'
            variables   = dict2Val(
                    parDic['ACS_BOUNDARY_SURFACES'][bndSrf]['variables'])
              'boundary_handle_last = handle_table.boundary_handles[1]' )
            for var in variables:
                if var not in allVars:
                    continue
                elif var == 'velocity':
                    sVars = ['x_velocity', 'y_velocity', 'z_velocity']
                    sVars = [ x for x in sVars if x not in variables ]
                    sVars = [ sVarDic[x] for x in sVars ]
                elif var == 'mesh_displacement':
                    if fsiFlag:
                        sVars = [   'x_mesh_displacement',
                        sVars = [ x for x in sVars if x not in variables]
                    else:
                        sVars = []
                else:
                    if 'mesh_displacement' in var:
                        if fsiFlag:
                            sVars = [ sVarDic[var] ]
                        else:
                            sVars = []
                    else:
                        if var in sVarDic:
                        else:
                            sVars = [ var ]
                for sVar in sVars:
                    fvxObj.writeVerbatim(text = \
                                        'modify(boundary_handle_last,'\
                                        '{types=%s, scalar_func="%s"})'\
                                        % (types, sVar) )
                    fvxObj.saveImage(fileName="%s_%s.jpg" % (bndSrf,sVar))
        text = 'modify(boundary_handle_0,{visibility="off"})'           )
    if 'ACS_COORDINATE_SURFACES' in parDic:
        for crdSrf in parDic['ACS_COORDINATE_SURFACES']:
            bbox        = None
            lrange      = None
            axis        = dict2Val(
                parDic['ACS_COORDINATE_SURFACES'][crdSrf]['axis']       )
            point       = dict2Val(
                parDic['ACS_COORDINATE_SURFACES'][crdSrf]['point']      )
            if 'variables' in parDic['ACS_COORDINATE_SURFACES'][crdSrf]:
                  parDic['ACS_COORDINATE_SURFACES'][crdSrf]['variables'])
            else:
                  parDic['ACS_GLOBAL']['coordinate_variables'])
            if 'bounding_box' in parDic['ACS_COORDINATE_SURFACES'][crdSrf]:
                bbox = dict2Val(
                 parDic['ACS_COORDINATE_SURFACES'][crdSrf]['bounding_box'])
            else:
                bbox = dict2Val(
                  parDic['ACS_GLOBAL']['coordinate_bounding_box'])
            if 'legend_range' in parDic['ACS_COORDINATE_SURFACES'][crdSrf]:
                lrange = dict2Val(
                 parDic['ACS_COORDINATE_SURFACES'][crdSrf]['legend_range'])
            else:
                lrange = dict2Val(
                  parDic['ACS_GLOBAL']['coordinate_legend_range'])
            if axis[0] == 1.0:
                Byc = Bya
                Bzc = Bza
                if bbox != None:
                    dr1_axis_min= str(bbox[2])
                    dr1_axis_max= str(bbox[3])
                    dr2_axis_min= str(bbox[4])
                    dr2_axis_max= str(bbox[5])
                    Byc = (bbox[3]+bbox[2])/2
                    Bzc = (bbox[5]+bbox[4])/2
                lookat  = "{%6.3f,%6.3f,%6.3f,}" % ( Bxa, Byc, Bzc )
                lookfrom= "{%6.3f,%6.3f,%6.3f,}" % ( Bx2, Byc, Bzc )
                center  = "%6.3f %6.3f %6.3f" % ( Bxa, Byc, Bzc )
                axis_new= 'X'
                axis_dr1= 'Y'
                axis_dr2= 'Z'
                axis_cur= point[0]
                sclRat  = max(  (Ty2-Ty1)/(bbox[3]-bbox[2]),
                                (Tz2-Tz1)/(bbox[5]-bbox[4]) )
                imgRat  = max(  (bbox[5]-bbox[4])/(bbox[3]-bbox[2]),
                                (bbox[3]-bbox[2])/(bbox[5]-bbox[4]) )
                zoom    = 2 * sclRat #* imgRat
            if axis[1] == 1.0:
                Bxc = Bxa
                Bzc = Bza
                if bbox != None:
                    dr1_axis_min= str(bbox[0])
                    dr1_axis_max= str(bbox[1])
                    Bxc = (bbox[1]+bbox[0])/2
                lookat  = "{%6.3f,%6.3f,%6.3f,}" % ( Bxc, Bya, Bzc )
                lookfrom= "{%6.3f,%6.3f,%6.3f,}" % ( Bxc, By1, Bzc )
                center  = "%6.3f %6.3f %6.3f" % ( Bxc, Bya, Bzc )
                axis_new= 'Y'
                axis_dr1= 'X'
                axis_dr2= 'Z'
                axis_cur= point[1]
                sclRat  = max(  (Tx2-Tx1)/(bbox[1]-bbox[0]),
                imgRat  = max(  (bbox[5]-bbox[4])/(bbox[1]-bbox[0]),
                                (bbox[1]-bbox[0])/(bbox[5]-bbox[4]) )
            if axis[2] == 1.0:
                Bxc = Bxa
                Byc = Bya
                if bbox != None:
                    dr2_axis_min= str(bbox[2])
                    dr2_axis_max= str(bbox[3])
                lookat  = "{%6.3f,%6.3f,%6.3f,}" % ( Bxc, Byc, Bza )
                lookfrom= "{%6.3f,%6.3f,%6.3f,}" % ( Bxc, Byc, Bz2 )
                center  = "%6.3f %6.3f %6.3f" % ( Bxc, Byc, Bza )
                axis_new= 'Z'
                axis_dr1= 'X'
                axis_dr2= 'Y'
                axis_cur= point[2]
                                (Ty2-Ty1)/(bbox[3]-bbox[2])   )
                imgRat  = max(  (bbox[3]-bbox[2])/(bbox[1]-bbox[0]),
                                (bbox[1]-bbox[0])/(bbox[3]-bbox[2]) )
            fvxObj.writeVerbatim( "view_table_1.angle_axis.at=%s"%lookat)
            fvxObj.writeVerbatim("view_table_1.angle_axis.up=%s"%axis_up)
                try:
                    if lrange != []:
                        if isinstance(lrange[0], list):
                            scalar_min = lrange[variables.index(var)][0]
                            scalar_max = lrange[variables.index(var)][1]
                        else:
                            scalar_min = lrange[0]
                            scalar_max = lrange[1]
                    else:
                        scalar_min = 'Auto'
                        scalar_max = 'Auto'
                except:
                    scalar_min = 'Auto'
                    scalar_max = 'Auto'
                    continue
                    if fsiFlag:
                    else:
                        sVars = []
                else:
                        if fsiFlag:
                        else:
                            sVars = []
                    else:
                        if var in sVarDic:
                        else:
                            sVars = [ var ]
                for sVar in sVars:
                    if scalar_min != 'Auto' and scalar_max != 'Auto':
                                    'modify(coordinate_handle_3,'\
                                    '{axis="%s", %s_axis={current=%f},'\
                                    '%s_axis={min=%s, max=%s},'\
                                    'scalar_func="%s",'\
                                    'scalar_range={min=%s, max=%s},'\
                                    'visibility="on"})'\
                                    % (axis_new,axis_new,axis_cur,
                                    axis_dr1,dr1_axis_min,dr1_axis_max,
                                    axis_dr2,dr2_axis_min,dr2_axis_max,
                                    sVar,scalar_min,scalar_max ) )
                    elif scalar_min != 'Auto' and scalar_max == 'Auto':
                                    'scalar_range={min=%s},'\
                                    sVar,scalar_min ) )
                    elif scalar_min == 'Auto' and scalar_max != 'Auto':
                                    'scalar_range={max=%s},'\
                                    sVar,scalar_max ) )
                    else:
                                    'scalar_func="%s",visibility="on"})'\
                                    sVar ) )
                    fvxObj.saveImage(fileName="%s_%s.jpg" % (crdSrf,sVar))
            text = 'coordinate_handle_3 = handle_table.coord_handles[4]')
    acuHome     = os.getenv(    "ACUSIM_HOME"                           )
    acuMach     = os.getenv(    "ACUSIM_MACHINE"                        )
    reportDir   = os.path.join( acuHome, acuMach, 'plugins', 'report'   )
    initFile    = os.path.join( reportDir, 'init.frm' )
    initFile    = fvxObj.getUnixPath(   initFile    )
    fvxObj.readFormula(  fileName = "%s"  % initFile)
    if tDir == 1:
    if tDir == 2:
    lookfrom = "{%6.3f,%6.3f,%6.3f,}" % ( Bxf, Byf, Bzf )
    fvxObj.writeVerbatim( text = 'set_view( view_table_1)')
    fvxObj.addIsoSrf(   "iso_srf_1",
                        show_mesh           = "off" ,
                        iso_func            = "Q",
                        iso_value_current   = 1                         )
    fvxObj.writeIsoSrf( "iso_srf_1")
        text = 'set_legend("1","0.95","0.85","ISO",1)'                  )
    text='modify(   boundary_handle_0,{visibility="off"})'              )
    fvxObj.saveImage(   fileName = "iso_velocity.jpg"                   )
    fvxObj.writeVerbatim( text = 'delete(strm_ln_0)'                    )
    fvxObj.writeVerbatim( text = 'delete(coordinate_surface_3)'         )
    fvxObj.writeVerbatim( text = 'delete(coordinate_surface_2)'         )
    fvxObj.writeVerbatim( text = 'delete(coordinate_surface_1)'         )
    fvxObj.writeVerbatim( text = 'delete(coordinate_surface_0)'         )
    fvxObj.writeVerbatim( text = 'delete(boundary_handle_1)'            )
    fvxObj.writeVerbatim( text = 'delete(boundary_handle_0)'            )
    fvxObj.close()
    fvxObj.runAcuFieldView()
    fvxObj.clear()
        if digits != -1:
            createVideo( digits )
# SetUp
print  "Set Up"
problem = acuCnf.cnfGetStr( "problem"   )
runId   = acuCnf.cnfGetInt( "run_id"    )
if runId == 0:
    Index   = getMaxFileInd( problem, "Log" )
    if Index == -1:
        runId   = 1
    else:
        runId   = Index
logFile = "%s.%d.Log" % (   problem , runId )
texFile = problem + ".tex"
parFile = problem + ".vpar"
fvxFile = problem + ".fvx"
print  "Log File = %s " % logFile
# WT component names
wtComps                 = {}
wtComps['BODY'     ]    = ( 'solid', [ 1.0, 0.0, 0.0 ], 'on', 'off' )
wtComps['POROUS'   ]    = ( 'solid', [ 1.0, 0.0, 0.0 ], 'on', 'off' )
wtComps['WT_BOTTOM']    = ( 'solid', [ 0.0, 1.0, 1.0 ], 'on', 'off' )
wtComps['WT_INLET' ]    = ( 'solid', [ 0.0, 1.0, 0.0 ], 'on', 'on'  )
wtComps['WT_OUTLET']    = ( 'solid', [ 0.0, 0.0, 1.0 ], 'on', 'on'  )
wtComps['WT_LEFT'  ]    = ( 'solid', [ 1.0, 1.0, 0.0 ], 'on', 'on'  )
wtComps['WT_RIGHT' ]    = ( 'solid', [ 0.0, 1.0, 1.0 ], 'on', 'on'  )
wtComps['WT_TOP'   ]    = ( 'solid', [ 1.0, 0.0, 1.0 ], 'on', 'on'  )
wtComps['WT_SYMMETRY' ] = ( 'solid', [ 1.0, 0.0, 1.0 ], 'on', 'on'  )
for i in range( 24 ):
    ikey            = 'WHEEL_%d' % i
    wtComps[ikey]   = ( 'solid', [ 1.0, 0.0, 1.0 ], 'on', 'off' )
for i in range( 10 ):
    ikey            = 'flex_comp_%d' % (i+1)
compNames   = wtComps.keys()
( compMap, parDic, fsiDic ) = readVars( parFile, compNames )
invCompMap  = {}
for ikey in compMap:
    vals    = compMap[ikey]
    for val in vals:
        invCompMap[val] = ikey
othDir = getMonitorPoints(parDic)
optDir = {}
# Open a document
rep = Report(   texFile,
                packages = ("graphicx","hyperref","geometry","movie15") )
rep.modifyPackageOptions(   "hypersetup",
                            optionMap={"pdfborder":"{0 0 0}"}           )
# Open the model and solution
adb = Adb( )
# Front Page
rho     = 1.225
Aref    = 1
Ainl    = 1
fDir    = 0
tDir    = 1
cDir    = 2
Vin     = 1.0
(Bx1, Bx2, By1, By2, Bz1, Bz2) = [ 0.0, 1.0, 0.0, 1.0, 0.0, 1.0 ]
(Tx1, Tx2, Ty1, Ty2, Tz1, Tz2) = [ 0.0, 1.0, 0.0, 1.0, 0.0, 1.0 ]
if 'body_bounding_box' in parDic['ACS_GLOBAL']:
    body_bounding_box = parDic['ACS_GLOBAL']['body_bounding_box']
    (Bx1, Bx2, By1, By2, Bz1, Bz2)  = dict2Val(     body_bounding_box   )
if 'tunnel_bounding_box' in parDic['ACS_GLOBAL']:
    tunnel_bounding_box = parDic['ACS_GLOBAL']['tunnel_bounding_box']
    (Tx1, Tx2, Ty1, Ty2, Tz1, Tz2)  = dict2Val(     tunnel_bounding_box )
Txl = Tx2-Tx1
Tyh = Ty2-Ty1
Tzw = Tz2-Tz1
Bxl = Bx2-Bx1
Byh = By2-By1
Bzw = Bz2-Bz1
if 'reference_area' in parDic['ACS_GLOBAL']:
    Aref    = dict2Val(     parDic['ACS_GLOBAL']['reference_area']      )
else:
    if fDir == 0:
        Aref    = abs(By2-By1)*abs(Bz2-Bz1)
    if fDir == 1:
        Aref    = abs(Bz2-Bz1)*abs(Bx2-Bx1)
    if fDir == 2:
        Aref    = abs(Bx2-Bx1)*abs(By2-By1)
if 'inlet_area' in parDic['ACS_GLOBAL']:
    Ainl    = dict2Val(     parDic['ACS_GLOBAL']['inlet_area']          )
else:
    if fDir == 0:
        Ainl    = abs(Ty2-Ty1)*abs(Tz2-Tz1)
    if fDir == 1:
        Ainl    = abs(Tz2-Tz1)*abs(Tx2-Tx1)
    if fDir == 2:
        Ainl    = abs(Tx2-Tx1)*abs(Ty2-Ty1)
Brat= Aref/Ainl*100
    figExt = "jpg";
else:
    figExt = "jpeg";
if 'ACS_MATERIAL_MODELS' in parDic:
    for matMdl in parDic['ACS_MATERIAL_MODELS']:
        rho = dict2Val(parDic['ACS_MATERIAL_MODELS'][matMdl]['density'])
        break
else:
    rho = 1.225
#createResidualSolutionRatios( rep, adb )
createResultData(   rep, adb, compMap, parDic, fsiDic,
                    othDir, rho, Aref, fDir, tDir, cDir )
createImages(   rep, compMap, parDic, fsiDic, rho       )
rep.newPage()
rep.addSpace( 2 )
logoFile    = os.path.join( acuHome, acuMach, 'plugins',
                            'report', 'logo_altair.png' )
newFile     = 'logo.png'
    shutil.copy( logoFile, newFile )
    logoFile    = newFile
if os.path.exists( logoFile ):
    rep.addImage( logoFile, scale = 2,)
rep.addSpace( 2 )
imgFct = 640/ ( 6.0 * 72 )
rep.addTitle( "Wind Tunnel Simulation" )
if "engineerName" in parDic['ACS_GLOBAL']:
    engName = "Engineer name: %s" % dict2Val(
                                    parDic['ACS_GLOBAL']['engineerName'])
    rep.addTitle( engName )
rep.fillVSpace( )
rep.addDate( )
rep.addImage( "wnd_tun_log.%s" % figExt, scale = 1.0/imgFct,)
rep.fillVSpace( )
rep.addText( "\\emph{Product of Altair Engineering Inc.}", "center" )
rep.addText( "http://www.altair.com", "center" )
rep.newPage( )
# Table of Contents
rep.addTableOfContent( )
rep.newPage( )
# Introduction
rep.addSection( "Summary" )
rep.addText("This report summarizes the results of an external"\
            "aerodynamic CFD analysis performed by "\
            "Altair\\textquoteright s Virtual Wind Tunnel, "\
            "leveraging AcuSolve\\textquoteright s CFD technology."     )
rep.addText(" ")
rep.addText("The first section provides a brief overview of the"\
            " run and its results."                                     )
nElms       = adb.get( "nElms" )
nTotElems   = 0
for i in range( nElms ):
    nTotElems = nTotElems + adb.get( "nElmElems", i )
cpuTimes    = adb.getCpuTimes()
elapseTimes = adb.getElapseTimes()
cpuHrs      = cpuTimes.sum() / 3600.0
elapseHrs   = elapseTimes.sum() / 3600.0
summTable   = []
runVersion  = adb.get( 'runVersion' )
summTable.append( ( "AcuSolve version", "%s" % runVersion ) )
    summTable.append( ( "Simulation type", "%s" % dict2Val(
                        parDic['ACS_GLOBAL']['simulationType'] ) )      )
summTable.append( ( "Element count", "%d" % nTotElems   ) )
summTable.append( ( "Run time ( Elapse time )", "%6.3f h" % elapseHrs ) )
#summTable.append( ( "CPU time", "%6.3f h" % cpuHrs      ) )
    keyCount = 0
        if dict2Val(
           parDic['ACS_COMPONENTS'][comp]['wtcomp'] ) == "WT_INLET":
            keyCount    += 1
            if 'velocity' in parDic['ACS_COMPONENTS'][comp]:
                velocity    = dict2Val(
                            parDic['ACS_COMPONENTS'][comp]['velocity']  )
            else:
                velocity    = ( dict2Val(
                        parDic['ACS_GLOBAL']['inletVelocity'] ),0.0,0.0 )
            ( xVel, yVel, zVel ) = velocity
            summTable.append( ( "%s" % str( comp ).replace( "_", "\_" ),
                          "%.2f %.2f %.2f m/s" % ( xVel, yVel, zVel ) ) )
    if keyCount == 0:
        summTable.append( ( "Inflow velocity", "%s m/s" % dict2Val(
                            parDic['ACS_GLOBAL']['inletVelocity'] ) )   )
summTable.append( ( "Drag coefficient, Cd", "%6.3f" % \
                    dataTable[len(dataTable)-1][1] )                    )
summTable.append( ( "Lift coefficient, Cl", "%6.3f" % \
                    dataTable[len(dataTable)-1][2] )                    )
rep.addTable( summTable, "Problem Information", ref="tab:summ")
# Geometry
rep.addSection( "Dimensions" )
rep.addText("This sections contains geometric dimensions"\
            "related to the wind tunnel and the body."                  )
dimmTable   = [ ( "Wind tunnel, bounding box",
                "[%6.3f, %6.3f], [%6.3f, %6.3f], [%6.3f, %6.3f]" % \
                (Tx1, Tx2, Ty1, Ty2, Tz1, Tz2)  )                       ]
dimmTable.append( ( "Body, bounding box",
                (Bx1, Bx2, By1, By2, Bz1, Bz2)  )                       )
dimmTable.append( ( "Wind tunnel dimension",
                    "%6.3f m x %6.3f m x %6.3f m." % (Txl, Tyh, Tzw))   )
dimmTable.append( ( "Body dimension",
                    "%6.3f m x %6.3f m x %6.3f m." % (Bxl, Byh, Bzw))   )
dimmTable.append( ( "Frontal ref. area, Aref", "%s m^{2}" % Aref    )   )
dimmTable.append( ( "Blockage ratio \\%", "%s" % Brat               )   )
dimmTable.append( ( "Distance inflow - body", "%6.3f m" % abs(Bx1-Tx1)) )
rep.addTable( dimmTable, "Geometric Dimensions", ref="tab:dimm")
rep.newPage( )
rep.addFigure( "tun_bdy_vew.%s" % figExt,
    scale=1.0/imgFct, caption = "Virtual Wind Tunnel", ref="fig:tunbdy" )
rep.addSection( "Mesh" )
rep.addText("This section contains mesh statistics and screen"\
            "shots of several cutting planes through the mesh."         )
nNodes      = adb.get("nNodes")
meshTable   = []
meshTable.append( (     "Numb. of nodes", "%d" % nNodes             )   )
meshTable.append( (     "Numb. of elements", "%d" % nTotElems       )   )
if 'nZones' in parDic['ACS_GLOBAL']:
    meshTable.append( ( "Numb. of refinement zones",
                    "%s" % dict2Val(parDic['ACS_GLOBAL']['nZones'] ) )  )
rep.addTable(       meshTable, "Mesh statistics", ref="tab:mesh"        )
meshFigTable = [ ( "Figure \\ref{fig:flowmesh}", "Symmetry plane " )    ]
meshFigTable.append( ( "Figure \\ref{fig:crossmesh}", "Cross section" ) )
rep.addTable(   meshFigTable,
                "Cutting planes through mesh", ref="tab:meshFig"        )
rep.newPage()
rep.addFigure(  "coord_mesh.%s" % figExt, scale = 1.0 / imgFct,
                caption = "Mesh in Flow Direction", ref = "fig:flowmesh")
rep.addFigure(  "coord_mesh2.%s" % figExt, scale = 1.0 / imgFct,
                caption = "Mesh in Cross Direction", ref="fig:crossmesh")
rep.fillVSpace()
# Boundary Conditions and Solution Strategy
rep.newPage( )
rep.addSection( "Boundary Conditions and Solution Strategy"             )
rep.addText("In this section the boundary conditions and "\
            "the setup for the CFD run are listed."                     )
boundTable  = []
leftCount   = 0
rightCount  = 0
    keyCount = 0
        if dict2Val(
            keyCount    += 1
            else:
            boundTable.append( ( "%s" % str( comp ).replace( "_", "\_" ),
                            "%.2f %.2f %.2f m/s" % ( xVel, yVel, zVel )))
            if 'Wind_Tunnel_Left' in comp:
                leftCount += 1
            if 'Wind_Tunnel_Right' in comp:
                rightCount += 1
    if keyCount == 0:
        boundTable.append( ( "Inflow velocity",
            "%s m/s" % dict2Val(parDic['ACS_GLOBAL']['inletVelocity'] )))
keyCount = 0
    if dict2Val(parDic['ACS_COMPONENTS'][comp]['wtcomp']) == "WT_OUTLET":
        keyCount += 1
                                "Pressure outlet"                   )   )
            leftCount += 1
            rightCount += 1
if keyCount == 0:
    boundTable.append(  (   "Outflow",  "Pressure outlet"   )   )
if leftCount > 0 and rightCount > 0:
    slipFaces = "Top face of wind tunnel"
elif leftCount > 0 and rightCount == 0:
    slipFaces = "Top, right faces of wind tunnel"
elif leftCount == 0 and rightCount > 0:
    slipFaces = "Top, left faces of wind tunnel"
else:
    slipFaces = "Top, right, left faces of wind tunnel"
boundTable.append( ("Slip Walls", "%s" % slipFaces  ) )
boundTable.append( ("No-slip Walls",
                    "wind tunnel ground, body, wheels, heat-exchange" ) )
rep.addTable(   boundTable, "Boundary conditions", ref = "tab:bound"    )
solTable =  []
    solTable.append( (  "Simulation type", "%s" % dict2Val(
    if 'nTimeSteps' in parDic['ACS_GLOBAL']:
        try:
            nSteps = adb.get('nSteps')
        except:
            nSteps = dict2Val( parDic['ACS_GLOBAL']['nTimeSteps'] )
        solTable.append( ( "Number of time steps", "%s" % nSteps ) )
    if 'timeIncr' in parDic['ACS_GLOBAL'] and \
       dict2Val( parDic['ACS_GLOBAL']['simulationType'] ) == "transient":
        try:
            timeInc= adb.get('timeInc',nSteps-1)
            time   = adb.get('time',nSteps-1)
        except:
            nSteps = dict2Val(parDic['ACS_GLOBAL']['nTimeSteps'])
            timeInc= dict2Val(parDic['ACS_GLOBAL']['timeIncr'])
            time   = nSteps * timeInc
        solTable.append( ( "Time increment", "%s" % timeInc ) )
        solTable.append( ( "Physical time", "%6.3f" % time ) )
if dict2Val( parDic['ACS_GLOBAL']['simulationType'] ) == "transient":
    solTable.append( ( "Turbulence model", "Detached Eddy Simulation" ) )
else:
    solTable.append( ( "Turbulence model", "Spalart-Allmaras" )         )
if 'movingGround' in parDic['ACS_GLOBAL']:
    if dict2Val( parDic['ACS_GLOBAL']['movingGround'] ) == 1:
        mgVal   = True
    elif dict2Val( parDic['ACS_GLOBAL']['movingGround'] ) == 0:
        mgVal   = False
    else:
        mgVal   = dict2Val( parDic['ACS_GLOBAL']['movingGround'] )
    solTable.append( ( "Moving ground", "%s" % mgVal    ) )
if 'rotatingWheels' in parDic['ACS_GLOBAL']:
    if dict2Val( parDic['ACS_GLOBAL']['rotatingWheels'] ) == 1:
        rwVal   = True
    elif dict2Val( parDic['ACS_GLOBAL']['rotatingWheels'] ) == 0:
        rwVal   = False
    else:
        rwVal   = dict2Val( parDic['ACS_GLOBAL']['rotatingWheels'] )
    solTable.append( ( "Rotating wheels", "%s" % rwVal   ) )
rep.addTable( solTable, "Solution Strategy", ref="tab:sol")
matTable = []
        matDens = dict2Val( parDic['ACS_MATERIAL_MODELS'][matMdl]['density'] )
        matVisc = dict2Val( parDic['ACS_MATERIAL_MODELS'][matMdl]['viscosity'] )
        break
else:
    matDens = 1.225
    matVisc = 1.781e-5
matTable.append( ( "Density", "%s kg/m3" % matDens ) )
matTable.append( ( "Dynamic Viscosity", "%s kg/m-sec" % matVisc ) )
rep.addTable( matTable, "Material Model", ref="tab:mat" )
# Results
rep.addSection("Results")
rep.addText("In this section the results of the CFD run are reported. "\
            "Table \\ref{tab:res} gives an overview of the different "\
            "result types."                                             )
fsiFlag = False
        fsiFlag = True
dirEntries      = os.listdir( os.path.join( os.getcwd(), 'Figures' ) )
monitorPoints   = ""
ref             = ""
fileNames       = []
for item in dirEntries:
    if 'pressure' in item:
        monitorPoints   = monitorPoints + "pressure, "
        ref             = ref + "\\ref{fig:pressCrv}, "
        fileNames.append(item)
    elif 'vel' in item:
        monitorPoints   = monitorPoints + "velocity, "
        ref             = ref + "\\ref{fig:velCrv}, "
    elif 'disp' in item:
        monitorPoints   = monitorPoints + "displacement, "
        ref             = ref + "\\ref{fig:dispCrv}, "
    elif 'visc' in item:
        monitorPoints   = monitorPoints + "eddy_viscosity, "
        ref             = ref + "\\ref{fig:viscCrv}, "
monitorPoints   = monitorPoints.rsplit(',' , 1)[0]
ref             = ref.rsplit(',' , 1)[0]
comps           = ref.split(',')
for ind,comp in enumerate(comps):
    comps[ind]  = comp.split('{')[-1].split('}')[0]
resTable = []
resTable.append( ( "Table \\ref{tab:coeff}",
    "Drag, lift and cross coefficient of "\
    "individual parts and their totals"                             )   )
resTable.append( ( "Table \\ref{tab:areas}",
    "Drag area of individual parts and their totals"                )   )
resTable.append( ( "Figure \\ref{fig:crvList1}",
    "Drag, lift and cross coefficient history"                      )   )
resTable.append( ( "Figure \\ref{fig:bdypres}",
    "Pressure contours on body"                                     )   )
resTable.append( ( "Figure \\ref{fig:mppress}",
    "Pressure coefficient on body surface"                          )   )
resTable.append( (
    "Figure \\ref{fig:bdyplusf}, \\ref{fig:bdyplusr}, \\ref{fig:bdyplusb}",
    "Body Surface y+ contours"                                      )   )
resTable.append( ( "Figure \\ref{fig:strmtp}, \\ref{fig:strmsd}",
    "Streamlines around body"                                       )   )
compfsi = "Figure"
if fsiFlag:
    resTable.append( (  "Table \\ref{tab:flex}",
        "Drag, lift and cross coefficients for the flexible components"))
    resTable.append( (  "Table \\ref{tab:monitor}",
                        "Monitor point information"                 )   )
    for comp in fsiDic:
        compfsi = compfsi + " \\ref{fig:yPlus_%s}" % str(comp)
    resTable.append( (  "%s" % compfsi,
                        "y+ Contour plots for flexible components"  )   )
    compStr = ""
    for file,comp in zip(fileNames,comps):
        compStr = compStr + " \\ref{%s}," % str(comp)
    resTable.append( ( "Figure%s" % compStr,
        "Displacement, pressure and velocity curves for monitor points"))
rep.addTable(       resTable,       "Results",      ref = "tab:res"     )
rep.newPage( )
rep.addTable(       dataTable,      "Coefficients", ref = "tab:coeff"   )
rep.fillVSpace( )
rep.addTable(       areaDataTable,  "Drag Areas",   ref = "tab:areas"   )
rep.fillVSpace( )
rep.addText("To compute the above aerodynamic coefficients, "\
            "the following equations are used"                          )
rep.beginBullet()
rep.addText( "\\addtolength{\itemindent}{1.5cm}" )
rep.addItem( "\\indent Drag coefficient, "\
        "C_{d}=\\frac{2\\times F_{x}}{rho\\times v^{2}\\times A_{ref}}",
        name = ""                                                       )
rep.endBullet()
rep.addText("")
rep.beginBullet()
rep.addItem( "\\indent Lift coefficient, "\
        "C_{l}=\\frac{2\\times F_{z}}{rho\\times v^{2}\\times A_{ref}}",
        name = ""                                                       )
rep.endBullet()
rep.addText("")
rep.beginBullet()
rep.addItem( "Cross coefficient, "\
        "C_{c}=\\frac{2\\times F_{y}}{rho\\times v^{2}\\times A_{ref}}",
        name = ""                                                       )
rep.endBullet()
rep.addText(" with")
rep.beginBullet()
rep.addText( "\\addtolength{\itemindent}{2cm}" )
rep.addItem( "F_{x}, F_{y}, and F_{z},", name = "" )
rep.endBullet()
rep.addText("forces are acting on the body in x, y and z directions, "\
            "respectively"                                              )
rep.beginBullet()
        matDens=dict2Val(parDic['ACS_MATERIAL_MODELS'][matMdl]['density'])
        break
else:
    matDens = 1.225
rep.addItem( "rho is density of fluid (%s kg/m^3)" % matDens, name = "" )
rep.endBullet()
rep.addText("")
rep.beginBullet()
rep.addItem( "v_{}", name = "" )
rep.endBullet()
rep.addText("is free stream velocity")
rep.beginBullet()
rep.addItem( "A_{ref}", name = "" )
rep.endBullet()
rep.addText("is frontal projected area of the object")
rep.beginBullet()
rep.addItem( "Drag area, "\
        "C_{d}\\times A_{ref}=\\frac{2\\times F_{x}}{rho\\times v^{2}}",
        name = ""                                                       )
rep.endBullet()
rep.addText("")
rep.beginBullet()
rep.addItem( "Pressure coefficient, "\
        "C_{p}=\\frac{p-p_{infinity}}{0.5\\times rho\\times v^{2}}",
        name = ""                                                       )
rep.endBullet()
rep.fillVSpace()
    rep.addFigure( "Figures/Drag_Plots.png", scale = 1.0 / imgFct,
                    caption = "Coefficients", ref  = "fig:crvList1"     )
else:
    rep.addFigure(  plot1, scale = 1.0 / imgFct,
if fsiFlag:
    resTable.append( ( "\\ref{tab:flex}",
    rep.addTable( fsiTable, "Flexible Part Coefficients", ref="tab:flex")
    rep.fillVSpace( )
print  "Creating images"
nOutSteps=adb.get('nOutSteps')
outSteps=adb.get('outSteps')
outTimes=adb.get('outTimes')
pTim    = pressure[1]
pRes    = pressure[2]
    tranTime = outTimes[len(outTimes)-2]
else:
    tranTime = outTimes[len(outTimes)-1]
if ',' in monitorPoints:
    monitorPoints   = monitorPoints.rsplit(', ' , 1)[0] + ' and ' + \
                      monitorPoints.rsplit(', ' , 1)[1]
    ref             = ref.rsplit(', ', 1)[0] + ' and ' + \
                      ref.rsplit(', ',1)[1]
othTable = [ ("Monitor name", "coordinates") ]
for item in othDir:
    x           = othDir[item]['coords'][0]
    y           = othDir[item]['coords'][1]
    z           = othDir[item]['coords'][2]
    tableItem   = ( str(item), "(%6.3f,%6.3f,%6.3f)" % ( x, y, z ) )
    othTable.append(tableItem)
if ref:
    resTable.append( ("%s" % ref, "Monitor points") )
    resTable.append( ("\\ref{tab:monitor}", "Monitor point information"))
    rep.addTable(othTable, "Monitor Point information",ref="tab:monitor")
        caption = ( file.rsplit('.',1)[0] ).replace('_', ' ')
            rep.addFigure( 'Figures/'+file, scale = 1.0/imgFct,
                            caption = caption, ref = comp )
        else:
            plotfn = os.path.splitext(file)[0]
            if plotfn in optDir.keys():
                plothnd = str(optDir[plotfn])
                rep.addFigure(plothnd, scale = 1.0 / imgFct,
                              caption = caption, ref = comp)
        for var in dict2Val(
          parDic['ACS_BOUNDARY_SURFACES'][bndSrf]['variables']  ):
            rep.addFigure( "%s_%s.%s" % (str(bndSrf),str(var),figExt),
            scale   = 1.0/imgFct,
            caption = "user defined boundary surface " + \
                      str(bndSrf) + '_' + str(var),
            ref     = "fig:%s_%s" % (str(bndSrf),str(var))              )
            variables = dict2Val( parDic['ACS_COORDINATE_SURFACES'][crdSrf]['variables'] )
        else:
            variables = dict2Val( parDic['ACS_GLOBAL']['coordinate_variables'] )
            if var in sVarDic:
                sVar = sVarDic[var]
            else:
                sVar = var
            caption = "%s on %s" % ( str(sVar), str(crdSrf) )
            rep.addFigure( "%s_%s.%s" % (str(crdSrf),str(sVar),figExt),
                        scale   = 1.0/imgFct,
                        caption = caption.replace('_',' '),
                        ref     = "fig:%s_%s" % (str(crdSrf), str(sVar)))
rep.newPage( )
rep.addFigure( "bnd_press.%s" % figExt,     scale = 1.0/imgFct,
        caption = "Body Surface Pressure Contours", ref = "fig:bdypres" )
rep.addFigure( "coord_press22.%s" % figExt, scale = 1.0/imgFct,
        caption = "Mid Plane Pressure Contours", ref = "fig:mppress2"   )
rep.addFigure( "coord_press2.%s" % figExt,  scale = 1.0/imgFct,
        caption = "Cross Plane Pressure Contours", ref = "fig:cppress"  )
rep.addFigure( "coord_press.%s" % figExt,   scale = 1.0/imgFct,
        caption = "Body Surface Pressure Coefficient", ref="fig:mppress")
rep.newPage( )
rep.addFigure( "coord_velocity.%s" % figExt,    scale = 1.0/imgFct,
            caption = "Mid Plane Velocity Contours", ref = "fig:mpvel"  )
rep.addFigure( "coord_velocity2.%s" % figExt,   scale = 1.0/imgFct,
            caption = "Cross Plane Velocity Contours", ref = "fig:cpvel")
rep.newPage( )
rep.addFigure( "body_y_plus_front.%s" % figExt, scale = 1.0/imgFct,
            caption = "Body Surface y+ Front View", ref = "fig:bdyplusf")
rep.addFigure( "body_y_plus_back.%s" % figExt,  scale = 1.0/imgFct,
            caption = "Body Surface y+ Rear View", ref = "fig:bdyplusr" )
rep.addFigure( "body_y_plus_bottom.%s" % figExt, scale = 1.0/imgFct,
            caption = "Body Surface y+ Bottom View", ref = "fig:bdyplusb")
rep.newPage( )
rep.addFigure( "stream_lines_1.%s" % figExt,    scale = 1.0/imgFct,
                caption = "Stream lines",   ref = "fig:strmtp"          )
rep.addFigure( "stream_lines_2.%s" % figExt,    scale = 1.0/imgFct,
                caption = "Stream lines Side View", ref = "fig:strmsd"  )
#rep.addFigure( "iso_velocity.%s" % figExt, scale=1.0/imgFct,
   #caption = "Iso Surface of Velocity for Q of 1 m/s", ref="fig:isovel")
for comp in fsiDic:
    resTable.append( ( "\\ref{fig:yPlus_%s}" % str(comp),
            "A y+ Contour plot for flexible component %s" % str(comp) ) )
    rep.addFigure( "y_plus_flex_%s.%s" % (str(comp), figExt),
        scale   = 1.0/imgFct,
        caption = "y+ Contour for flexible component " + str(comp),
        ref     = "fig:yPlus_%s" % str(comp)                            )
rep.newPage()
print  "Done."
# Summary
rep.addSection("References")
rep.beginBullet()
rep.addItem("Altair Engineering Inc, 2015,  Virtual Wind Tunnel, "\
            "Online Documentation", name = ""                           )
rep.addItem("Altair Engineering Inc, 2015,  AcuSolve Command "\
            "Reference Manual.", name = ""                              )
rep.addItem("Hucho, W.-H., 1997, Aerodynamics of Road Vehicles, "\
            "SAE, ISBN 0-7680-0029-7.", name = ""                       )
rep.endBullet()
rep.newPage()
# Close the report and make PDF
rep.close( )
rep.writePdf( )
# Remove temporary files
try:
    dir  = "Figures"
    for file in os.listdir( "Figures" ):
        os.remove( os.path.join( dir, file ) )
    os.rmdir( dir )
except:
    pass
