udfGetSdUsrIds()
Return the nodal user IDs for the nodes in the subdomain.
usrIds = udfGetSdUsrIds( udfHd ) ;
AcuSolve User-Defined Subdomain Routine
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- usrIds (Integer*)
- Pointer to one dimensional integer array of user IDs.
Integer* usrIds ;
Integer nNodes, node, usrNode ;
nNodes = udfGetNSdNodes( udfHd ) ;
for ( node = 0 ; node < nNodes ; node++ ) {
usrNode = usrIds[node] ;
}Errors
- This routine expects a valid udfHd.
- This routine may only be called within an external code.
