udfSetSig()
Set a signal to alter the behavior of AcuSolve.
udfSetSig( udfHd, name, value ) ;
AcuSolve User-Defined Function Basic
- udfHd
- The opaque handle (pointer) which was passed to the user function.
- name
- integerSymbolic name of the signal to be set
- UDF_SIG_NO_CONV
- Stagger not converged.
- UDF_SIG_DONT_AMP_TIMEINC
- Do not amplify time increment.
- UDF_SIG_REDUCE_TIMEINC
- Reduce time increment.
- UDF_SIG_REDO_STEP
- Redo time step.
- UDF_SIG_MUST_REDO_STEP
- Must redo time step.
- UDF_SIG_FATAL
- Fatal error, exit.
- UDF_SIG_STOP
- Stop at end of step.
- UDF_SIG_OUTPUT
- Output at end of step.
- UDF_SIG_OUTPUT_RESIDUAL
- Output nodal residual.
- UDF_SIG_PARTIAL_UPDATE
- Partially update solution.
- value (real)
- Value of the signal. Ignored except for UDF_SIG_PARTIAL_UPDATE name.
Return Value
None
udfSetSig( udfHd, UDF_SIG_STOP, 0 ) ;Errors
- This routine expects a valid udfHd.
- name must be one of the supported names.
