ACU-T: 4101 T-Junction Flow using the Eulerian Multiphase Model
Prerequisites
This tutorial provides the instructions for setting up and running a basic transient multiphase simulation using the Eulerian multiphase model. Prior to starting this tutorial, you should have already run through the introductory HyperWorks tutorial, ACU-T: 1000 HyperWorks UI Introduction, and have a basic understanding of HyperWorks CFD and AcuSolve. To run this simulation, you will need access to a licensed version of HyperWorks CFD and AcuSolve.
Problem Description
Start HyperWorks CFD and Open the HyperMesh Database
Validate the Geometry
Figure 3.
Set Up Flow
Assign Material Properties
Generate the Mesh
Define Nodal Outputs
Run AcuSolve
Post-Process the Results with HW-CFD Post
Summary
In this tutorial, you learned how to set up and solve a multiphase flow simulation using the Eulerian multiphase model available in AcuSolve using HyperWorks CFD. You started by importing the HyperWorks CFD input database and then defined the flow setup. Once the solution was computed, you created a contour plot of velocity and field volume fraction using HyperWorks CFD Post.
