Manufacturing Solutions
Unified environment for manufacturing process simulation, analysis, and design optimization.
HyperForm
- Benefits
- Introduces forming feasibility criteria early in product development, where the most significant improvements are possible
 - Accurately predicts the blank size for improved material utilization
 - Provides a powerful tool to modify and verify multiple process scenarios with the ability to record and reuse complex model setup for repeatability of best practices
 - Visualizes wrinkles and splits, and fixes problems before cutting any steel
 - Provides powerful geometric tools for designing binder and parametric addendum
 - Provides an automated approach for optimization of stamping processes
 - Minimizes material wastage via blank nesting
 - Model setup for tailor welded blank and layered blanks
 - New GUI to quickly set up optimization problems in sheet metal forming
 - Springback positioner – Positions the part after springback relative to tools based on user preferences.
 - Model setup for Hot stamping using LS-DYNA
 - Drastically reduces the overall product cycle
For more information, reference the Manufacturing Solver help manual.
HyperXtrude
- Benefits
- Easy to use interface
 - Meshing wizards for quick model setup
 - HyperXtrude Job Manager to submit and manage local/remote jobs
 - Built-in and expandable material database
 - Process specific model setup tools
 - Wizard for tool deflection analysis using Altair OptiStruct
- Metal Extrusion
- Extrusion wizard for setting up for all problem classes supported by the solver
 - Tools for bearing design and optimization
 - Tube extrusion wizard
 - Polymer Extrusion
- Wizard for extrusion using plate dies
 - Coextrusion wizard to simulate coextruded parts with or without metal inserts and tool
 - Interface to setup to runner balancing analysis
 - Interface to setup a generic melt flow analysis
 - Tire extrusion analysis wizard
 - Easy to use interface for CFD tetrameshing
HyperMold
- Moldex3D Solid
 - Moldex3D Shell
 - Moldflow (Midplane, Fusion, and Solid 3D)
 - HyperXtrude for Resin Transfer Molding
- Moldex3D
 - This user profile supports model setup for three dimensional injection
                            molding simulations using Moldex3D Solid solver.
- Benefits
- Easy to use meshing wizards for model creation
 - Support for standard and fast cool analysis
 - Model diagnostics (similar to the solver)
 - Moldflow
 - This user profile supports model setup for injection molding simulations
                            using Autodesk® Simulation Moldflow® software.
- Benefits
- Support for Midplane, Fusion (dual domain), and Flow3D analysis
 - Easy to use wizards to setup models for all three model types
 - Model diagnostics includes fusion mesh match estimator
 - Tools to create runner system and cooling circuits
 - RTM
 - This user profile supports model setup for resin transfer molding
                            simulations using HyperXtrude solver for
                            RTM.
- Benefits
- Solid meshing wizard to mesh the model starting from solids
 - Interface for material database to add, edit, and maintain material data
 - Tools to create boundary and process conditions
HyperWeld
- Benefits
- Easy to use wizard for setting up models for butt, edge, lap and T-joints
 - Tools to create and setup models with complex pin shapes and other joints not supported by the wizard
Results Mapper
- Benefits
- Incorporates the manufacturing effects into structural analysis
 - Open environment that allows mapping of data between arbitrary solvers
