Altair HyperGraph 2022.1 Release Notes
General
New Features
- Dark theme support for all 2D chart types and for the 3D chart type.
Enhancements
- Support for *.frf_amplitude and *.frf_angle files for the LS-Dyna solver in HyperGraph.
 - Corrected the variable names for the type cluster in T01 files for the Radioss solver.
 - Support for new time history output for /TRIA (2D solid element) for the Radioss solver.
 - Support for new outputs for the /TH/QUAD type for the Radioss solver.
 - Support for new output for Radioss time history type /TH/SLIPRING and /TH/RETRACTOR.
 - Support for unified OptiStruct format results in HyperGraph.
 - Identify the curve name in the legend when you click on a curve.
 - HyperWorks Command language (HWC) - Fitting the plot axis from both the Plot Browser and the View toolbar is recorded.
Resolved Issues
- Additional axis created when you create an extreme curve from a session containing a secondary axis.
 - Crash while loading PCH file.
 - HyperWorks HyperGraph performance compared to HyperGraph is slow when the data set contains more than 100,000 points.
 - Application crash while creating extreme curve after adding a HIC note.
 - Filters are not working on elout channel.
 - Delete key behavior from the Plot Browser when deleting curves.
 - Issue with TPL files generated from 2017 and loaded into 2021.
 - HG Apply Style dialog size reduction issue when moved to second monitor.
 - readsim function issue for garbage results.
 - HyperGraph fails to read the incremental results from a *.cntf file.
 - Issue with reading binout file from LS-Dyna.
 - The axis font options display incorrect default font family.
 - HyperWorks Command language (HWC) - Math operations and copy/paste of curves in the Plot Browser no longer record unnecessary fit commands.
Solver Interfaces
Abaqus Interface
Enhancements
- Abaqus 2022 ODB result file reading is supported for HyperGraph.
LS-DYNA Interface
Post-processing Enhancements
- Support for NVH/Frequency output files (frf_amplitude, frf_angle).
Resolved Issues
- Plotting elout history curves from a previously saved session file works.
Radioss Interface
- Corrected variable output names from /TH/CLUSTER.
 - Support for new output variables VX, VY, VZ, SSP, and MACH for /TH/QUAD and /TH/BRICK.
 - Support for new output variables from /TH/SLIPRING, /TH/RETRACTOR, /TH/SUBSET, and /TH/TRIA.
Resolved Issues
- /TH/SURF outputs selectable.
Extensions
New Features
The Extensions infrastructure providing the main entry point for custom content has been significantly enhanced:
- New Design of the Extension Manager
- Common appearance across applications
 - Detailed view with more information (Location Path, Help Link)
 - Multi-client Support
- Extensions can be developed for any HyperWorks client
 - Support of custom toolbars
 - Context Tcl API Commands
- Enter/exit and interact with a tool programmatically.
 - The list of new commands can be found in the Context Commands section.
Enhancements
The improvements to the Extension Manager include:
- Support of minimum product version
 - Deleted extensions are removed from the extension manager instantaneously
Known Issues
- Complete unloading of all GUI Elements like ribbon pages and loaded libraries/procedures requires an application restart.
 - Toolbars loaded with extensions are not exposed in the View – Toolbars menu.
Resolved Issues
- No more warning messages during deletion of extensions are shown.
