Altair HyperXtrude 2022.2 Release Notes
Altair HyperXtrude is a suite of finite element solvers for simulating the following
                manufacturing processes.
        - Binder Jet Sintering
 - Metal Extrusion
 - Polymer Extrusion
 - Quenching
 - Calibration
 - Metal Rolling
 - Friction Stir Welding
 - Resin Transfer Molding
Highlights
Highlights of this release include:
        - The metal extrusion solver now supports the variable bearing start feature
New Features
- Toppling prediction
 - The sintering solver predicts if the part will topple during the analysis. This feature is available for shrinkage and compensation analyses. This is enabled by default and can be modified using the parameter CheckToppling with values no or yes. The analysis is terminated if the part is going to tip over. (HXT-555)
 - Compensation correction algorithm
 - A new algorithm for computing compensation is implemented. Invoke by setting the CompensationCorrectionType to 1 (this is the new default).
Enhancements
- Improvements in contact behavior
- During compensation analysis, the tolerance for detecting contact with the base platform is increased.
 - The solver does not stop when self-contact occurs during compensation iterations. If there is such contact in the last step, an alert about the defect appears.
 - Export extract point results in CSV format
 - The sintering extract point results are now exported in a CSV format. This helps to easily plot and visualize these results. (HXT-569)
Resolved Issues
- Initial Grain Size
 - For the ArrheniusType1-Modified grain growth model, the solver no longer takes the final grain size of the previous compensation iteration as the initial size of the next iteration. (HXT-539)
 - Initial Relative Density
 - The issue of computed initial relative density (based on bounding volume) not within the accepted tolerance of input initial relative density is resolved. (HXT-561)
 - Extract point results
 - The extract point feature, which is used to extract all the relevant results at a given coordinate, is fixed and no longer causes a solver crash. This issue is resolved (HXT-565)
Metal Extrusion
New Features
- Non-uniform start of bearing regions
 - The solver module is now enhanced to support the non-uniform start of the bearing region in the model. In prior releases, the bearing region always starts with the BEARING3D region of the meshed model created either by drag or solid map. In this release, a new feature to consider non-uniform bearing start and especially before the start of the BEARING3D region (in the tet4-meshed zone) is implemented. This enables analysis of more complex dies with such bearing regions. When this feature is implemented in Inspire, the concept of starting the bearing profile curve in addition to the ending bearing profile curve will be introduced. This feature can now be used in place of mandrel offset for the inner bearing regions of a hollow profile. (HXT-216)
Enhancements
- Variable timestep determination in a multi-cycle analysis
 - Inspire Extrude interface has options to either automatically determine or manually specify the variable timestep data for transient analysis. This data is based on the meshed length of the billet. In a multi-cycle analysis, the solver automatically scales this data from cycle to cycle when the process data, mainly the billet length, changes due to the starter billet option. This module of the solver is greatly enhanced in this release by recomputing the data instead of a local scaling of the timestep.
Polymer Extrusion
New Features
- Wall slip model based on polymer viscosity
 - The current slip velocity model requires coefficients that are dependent
                            on the local viscosity of the polymer and the user is expected to input
                            the slip coefficient that can vary by orders of magnitude. To overcome
                            this limitation, a new wall slip model that internally accounts for the
                            local viscosity is implemented. For this model, the value of slip
                            coefficient C is specified as follows:
- C = 0 for full slip condition at the wall
 - C = 1 for a full stick condition at the wall
 - 0 < C < 1 for sliding friction at the wall
Quenching
Enhancements
- New heat transfer model for air fan quenching
 - A new correlation to compute the Nusselt number (and thereby the heat transfer coefficient) is implemented. This correlation accounts for the fan distance from the quench surface and the radial distance of the integration points from the fan axis through a geometric relationship. All dimensionless numbers in the correlations are computed at the film temperature. This results in improved accuracy of the of air fan quenching. (HXT-579)
