ADVC Interface 2022 Release Notes
Altair HyperMesh
Enhancements
- All float values are now exported in exponential format. Positive values have 12 digits (6 digits after decimals) and negative and zero values have 11 digits (5 digits after decimals).
 - Pretension directional vector component can be selected through graphics manipulator in addition to manual inputs.
 - load_id check box is added for $Load and $Pressure. You can turn it ON as per Random Response Analysis Set Up.
Resolved Issues
- Fixed a bug in custom import options where Loads and LoadCols were not working.
 - Fixed a bug where HyperMesh crashes if you import a file name that contains Japanese 2byte characters.
 - Fixed a bug where PhysicalQuantity and TimeStepControls were missing in the browser configuration.
 - Fixed a bug where the Behavior entity was not listed for the Includes View.
