Nastran Interface 2022.2 Release Notes
Altair HyperMesh
New Features
- Extension of Section Property tools
- Support for single beamsection creation
- Support for single beamsection creation of config Shell | Solid | Elastic sections from model data along with existing beam property update.
Enhancements
- Previous Section Property tool is extended to create single beamsections (without target beam) . The existing capability to update beam properties of several beams from an intersection with the model is contained inside the option Update beams.
- Solid beamsection config is now supported.
- New option to generate a sketch entity along with beamsection.
Resolved Issues
- 3D detailed visualization of Elastic section generated by Section Property is lost when opening an *.hm binary file if no sketch is assigned.
- Inconsistent creation of NLOUT card
- Quick find with incorrect tool tip for CPYRAM
