FKM Classification Parameters (Non-Welded)
The parameters for non-welded calculations are listed in both the Assign Material tab and the My Material tab of the Assign Material dialog.
The defaults are with respect to material = steel.
The following are the parameters listed in Assign Material tab.
Parameter Description
Effective Diameter (Deff) Effective diameter of the semi-finished product (default = 7.5mm)
Anisotropy factor (KA) Default = 0.9
Plastic Notch Factor – Nominal (Kp_sigma) Default = 1
Plastic Notch Factor – Shear (Kp_tau) Default = 1
Relative Stress Gradient X (G_sigmax) Relative stress gradient in normal direction (Default = 0.1 mm-1)
Relative Stress Gradient Y (G_sigmay) Relative stress gradient in normal direction (Default = 0.1 mm-1)
Relative Stress Gradient XY (G_sigmaxy) Relative stress gradient in shear direction (Default = 0.1 mm-1)
Overload Factor (Overloading) Parameter to decide overload situation. Options: F1, F2, F3, F4. Based on the selection, the fatigue limit calculation formula may vary. (Default – F2)
Surface Roughness (Rz) Average roughness of the component surface, (default = 100 μm)
Surface Treatment Factor (Kv) Default = 1
Coating Factor (Ks) Default = 1
Temperature Factor (Ktd) Default = 1
Material Safety factor (jF) Material safety factor for non-welded steel based on regular inspection (default = 1.5)
Load Safety factor (jS) Safety factor defined by design loads (default = 1.0)
Partial safety factor for allowable defects in castings (jG) Material safety factor for Casted materials (default =1, as just steel is supported)
Total Safety Factor (jD)
Total safety factor, based on jF, jS, jD and KT,D ,
jD = jS . (jF/ KT,D)
The following are the parameters listed in My Material tab.
Tensile Strength (Rm) Listed in SN tab (default = 300 N/mm2)
Yield Strength (Rp) Listed in SN tab (default = 180 N/mm2)
Elastic Modulus (E) Listed in SN tab (default = 2e5 N/mm2)
Strain At Break Point (A%) Listed in SN tab (default = 10% or 0.1)
Normal Fatigue Limit (σ_wzd) Listed in SN tab (default = 140 N/mm2)
Shear Fatigue Limit (τ_wzd) Listed in SN tab (default = 80 N/mm2)
Number of Cycles at Knee Point, Normal Stress (Nd_σ) Listed in SN tab (default = 1e6 cycles)
Number of Cycles at Knee Point, Shear Stress (Nd_τ) Listed in SN tab (default = 1e6 cycles)
SN curve slope, Normal Stress (K_σ) Listed in SN tab (default = 5)
SN curve slope, Shear Stress (K_τ) Listed in SN tab (default = 8)
Fatigue Stress Factor, Fully Reversed, Normal (fw_σ) Listed in Other tab (default = 0.4)
Fatigue Stress Factor, Fully Reversed, Shear (fw_τ) Listed in Other tab (default = 0.577)
Constant, Technological Size Factor for Tensile Strength (adm) Listed in Other tab (default = 0.15)
Constant, Technological Size Factor for Yield Strength (adp) Listed in Other tab (default = 0.4)
Constant, Technological Size Factor @ adm (Deff,N,m) Listed in Other tab (default = 40mm)
Non-linear Strain Stress Factor under bending – GJL (KNL) Listed in Other tab (default = 1.0)
aG Constant for (Kt-Kf) ratio for Fatigue Strength Factor (aG) Listed in Other tab (default = 0.4)
bG Constant for (Kt-Kf) ratio for Fatigue Strength Factor (bG) Listed in Other tab (default = 2400)
Constant For Roughness Factor, Normal Stress (aR_σ) Listed in Other tab (default = 0.22)
Minimum permissible tensile strength constant (Rm,N,min) Listed in Other tab (default = 400 N/mm2)
Constant for Mean Stress Sensitivity (aM) Listed in Other tab (default = 0.35)
Constant for Mean Stress Sensitivity (bM) Listed in Other tab (default = -0.1)
Compression Strength Factor, for tension, compression (f_σ) Listed in Other tab (default = 1.0)
Compression Strength Factor, Shear (f_τ) Listed in Other tab (default = 1.0)
Material Parameter Epsilon_0 (Epsilon_0) Listed in Other tab (default = 0.05)
Ductility factor (q) Listed in Other tab (default = 0)
Formulation
Current support in the evaluation build is for steel only.
Cyclic degree of utilization for normal and shear stresses:
Assessment
[ Stress amplitude / (critical amplitude/total safety factor)]
a B K x = σ a x / ( σ B K x / j D ) ≤ 1 , MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyyaiaadk eacaWGlbGaamiEaiabg2da9iabeo8aZjaadggacaWG4bGaai4lamaa bmaabaGaeq4WdmNaamOqaiaadUeacaWG4bGaai4laiaadQgacaWGeb aacaGLOaGaayzkaaGaeyizImQaaGymaiaacYcaaaa@4A3A@
a B K y = σ a y / ( σ B K y / j D ) ≤ 1 , MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyyaiaadk eacaWGlbGaamyEaiabg2da9iabeo8aZjaadggacaWG5bGaai4lamaa bmaabaGaeq4WdmNaamOqaiaadUeacaWG5bGaai4laiaadQgacaWGeb aacaGLOaGaayzkaaGaeyizImQaaGymaiaacYcaaaa@4A3D@
a B K x y = T a x y / ( T B K x y / j D ) ≤ 1 , MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyyaiaadk eacaWGlbGaamiEaiaadMhacqGH9aqpcaWGubGaamyyaiaadIhacaWG 5bGaai4lamaabmaabaGaamivaiaadkeacaWGlbGaamiEaiaadMhaca GGVaGaamOAaiaadseaaiaawIcacaGLPaaacqGHKjYOcaaIXaGaaiil aaaa@4B60@
Master Assessment Calculation
a N H = 1 2 · ( | a B K , x + a B K , y | + ( a B K , x − a B K , y ) 2 + 4 · a B K , τ 2 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyyamaaBa aaleaacaWGobGaamisaaqabaGccqGH9aqpdaWcaaqaaiaaigdaaeaa caaIYaaaaiabl+y6NnaabmaabaWaaqWaaeaacaWGHbWaaSbaaSqaai aadkeacaWGlbGaaiilaiaadIhaaeqaaOGaey4kaSIaamyyamaaBaaa leaacaWGcbGaam4saiaacYcacaWG5baabeaaaOGaay5bSlaawIa7ai abgUcaRmaakaaabaGaaiikaiaadggadaWgaaWcbaGaamOqaiaadUea caGGSaGaamiEaaqabaGccqGHsislcaWGHbWaaSbaaSqaaiaadkeaca WGlbGaaiilaiaadMhaaeqaaOGaaiykamaaCaaaleqabaGaaGOmaaaa kiabgUcaRiaaisdacqWIpM+zcaWGHbWaaSbaaSqaaiaadkeacaWGlb Gaaiilaiabes8a0bqabaGcdaahaaWcbeqaaiaaikdaaaaabeaaaOGa ayjkaiaawMcaaaaa@6314@
a G H = a B K , x 2 + a B K , y 2 − a B K , x · a B K , y + a B K , τ 2 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyyamaaBa aaleaacaWGhbGaamisaaqabaGccqGH9aqpdaGcaaqaaiaadggadaqh aaWcbaGaamOqaiaadUeacaGGSaGaamiEaaqaaiaaikdaaaGccqGHRa WkcaWGHbWaa0baaSqaaiaadkeacaWGlbGaaiilaiaadMhaaeaacaaI YaaaaOGaeyOeI0IaamyyamaaBaaaleaacaWGcbGaam4saiaacYcaca WG4baabeaakiabl+y6NjaadggadaWgaaWcbaGaamOqaiaadUeacaGG SaGaamyEaaqabaGccqGHRaWkcaWGHbWaa0baaSqaaiaadkeacaWGlb Gaaiilaiabes8a0bqaaiaaikdaaaaabeaaaaa@57B9@
a BK,σ v =q· a NH +( 1−q )· a GH ≤1 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyyamaaBa aaleaacaWGcbGaam4saiaacYcacqaHdpWCcaaMe8UaamODaaqabaGc cqGH9aqpcaWGXbGaeS4JPFMaamyyamaaBaaaleaacaWGobGaamisaa qabaGccqGHRaWkdaqadaqaaiaaigdacqGHsislcaWGXbaacaGLOaGa ayzkaaGaeS4JPFMaamyyamaaBaaaleaacaWGhbGaamisaaqabaGccq GHKjYOcaaIXaaaaa@516A@
Formulation for Static Assessment
The following process is followed for Static Assessment (non-welded):
  1. Equivalent Stress ( σ V MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaeq4Wdm3damaaBaaaleaapeGaamOvaaWdaeqaaaaa@3901@ ) = Maximum combined stress across all loadcases in the event.
  2. Calculate Static Strength ( σ S K MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacqaHdpWCpaWaaSbaaSqaa8qacaWGtbGaam4saaWdaeqaaaaa@39D8@ ).
    σ S K   =   R p   *   n p l MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacqaHdpWCpaWaaSbaaSqaa8qacaWGtbGaam4saiaacckaa8aabeaa k8qacqGH9aqpcaGGGcGaamOuaiaadchacaqGGaGaaiOkaiaabccaca WGUbGaamiCaiaadYgaaaa@43D9@
    R p MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGsbWdamaaBaaaleaapeGaamiCaaWdaeqaaaaa@3839@ = Modified yield strength calculated from Size factor, Anisotropy factor and Yield strength.
    n p l MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGUbWdamaaBaaaleaapeGaamiCaiaadYgaa8aabeaaaaa@3946@ = Plastic support factor.
  3. Calculate Static Utilization ( a S K MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamyya8aadaWgaaWcbaWdbiaadofacaWGlbaapaqabaaaaa@38F1@ )(1)
    a S K = σ V σ S K j D ≤ 1 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamyya8aadaWgaaWcbaWdbiaadofacaWGlbaapaqabaGcpeGaeyyp a0ZaaeWaa8aabaWdbmaalaaapaqaa8qacqaHdpWCpaWaaSbaaSqaa8 qacaWGwbaapaqabaaakeaapeWaaeWaa8aabaWdbmaalaaapaqaa8qa cqaHdpWCpaWaaSbaaSqaa8qacaWGtbGaam4saaWdaeqaaaGcbaWdbi aadQgapaWaaSbaaSqaa8qacaWGebaapaqabaaaaaGcpeGaayjkaiaa wMcaaaaaaiaawIcacaGLPaaacqGHKjYOcaaIXaaaaa@494C@
    j D MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaamOAa8aadaWgaaWcbaWdbiaadseaa8aabeaaaaa@381B@ = Total safety factor.
