Input Requirements
Discover the files required to work with HyperLife Weld Certification.
| File | Description | Remarks |
| FE Model File | The FE Model File | The current version of HL-WC
                                    supports model and results from the following solvers:
| FE Results File | The FE Results File | The FE Results must contain model data and stress results. |
| Weld Property File (Optional) | This file contains the data of all the classification parameters with respect to each weld line. | This file may not be available when working with a new model in HL-WC. |
