Visualize Results
Use the Evaluate tool explore the results of the run.
- Drag the slider on the legend to exclude certain value ranges from the visualization.
- Right-click on the legend to view options for numeric precision, format, level numbers, and model display.
Add Tags to Elements
Add a tag that displays an element's ID and utilization value.
Delete Tags
Remove element tags.
| Option | Description |
| Delete individual tags |
 Tip: To exit the context, click x on
                                the entity selector. |
| Delete all tags | Under the Tag field of the Results Explorer,
                            click  . |
Query Element Results
Use this option to query multiple elements and add their results to the Utilization Results report.
View Report
View the Utilization Results in a text file.
Text output contains the details of the critical evaluation locations and any element results that have been queried.
 to update
                    the results in the
 to update
                    the results in the  .
. on the
 on the
