Weld Templates
The default parameters shown in the Points tool related to Evaluation Distance, General, and Location Properties can be automatically updated using a weld template file (.xml).
The weld templates are sourced into the HyperLife Weld Certification session via the Weld Template folder. The default location defined in Preferences is: C:/Users/<user id>/Documents/Fatigue/WeldTemplates.
The .xml file placed in the weld template directory is automatically sourced into the session. The weld categories are listed in the Specifications and Points tools.
Apply Weld Templates in Specifications Tool
- Select the Regulation.
- Click to show weld templates.
- Select the weld cateogory for the required type.The template names for the weld type are listed from the weld template .xml saved in the Weld template directory.
- Select an Evaluation Method and click Apply.
Define Weld Template XML
<WeldPropertyTemplateData> root tag, as
                shown below. The tag has one attribute:
                version.<WeldPropertyTemplateData version="21.000000">….
</WeldPropertyTemplateData><Regulation> root tag, as shown
                below.<Regulation name="dvs1608">….
</Regulation>| Attribute | Valid Values |
| <Regulation name = “xxxxxx”> | dvs1608 dvs1612 eurocode3 fkm |
<WeldData> root
                tag, as shown
                    below.<WeldData Template name="T_Example" Weld_type="T" >
 <Table type="Evaluation_distance_table" Evaluation_Distance="Auto" Evaluation_Approach="Nominal">
 </Table>
 <Table type="General_table" >
 </Table>
 <Table type="Location_table">
 </Table>
</WeldData>| Attribute | Valid Values |
| Template_name | Name to be listed in weld category |
| Weld_type | T B L Cross Multiple O |
| Table type | Evaluation_distance_table General_table Location_table |
| Evaluation_Distance | Manual Auto |
| Evaluation_Approach | Nominal Hotspot |
Table type = Evaluation_distance_table
| Attributes | |
| Weld Factor | Default weld width factor to be used for Transverse,
                                    Longitudinal, and Shear directions. Example:
| Constant 1 | Constant * Min Shell thickness to be used for Transverse,
| Attributes | |
| 1st Total Distance | Total Distance at which stress is queried for Transverse,
                                    Longitudinal, and Shear directions. Example:  |
| Attributes | |
                                    Longitudinal, and Shear directions Example:  |
| Constant 1 | Constant 1 * Min Shell thickness to be used for Transverse,
| Constant 2 | Constant 2 * Min Shell thickness to be used for Transverse,
                                    Longitudinal and Shear directions. Example:  |
| Attributes | |
| Constant 1 | Constant 1 used in stress extrapolation for Transverse,
| Constant 2 | Constant 2 used in stress extrapolation for Transverse,
| 1st Total Distance | Total Distance(L1) at which stress is queried for Transverse,
| 2nd Total Distance | Total Distance(L2) at which stress is queried for Transverse,
Regulation name = dvs1608, Table type = General_table, and Table type = Location_table
| Attributes | |
| Mean Stress Sensitivity - Normal | Default = 0.15 |
| Mean Stress Sensitivity - Shear | Default = 0.09 |
| Grinding Bonus | Yes / No |
| Effective Weld Thickness | Yes / No |
| Attributes | |
| Notch Class - Transverse | Notch Class - Transverse for all locations Default = F2 |
| Notch Class - Longitudinal | Notch Class - Longitudinal for all locations Default = F2 |
| Notch Class - Shear | Notch Class - Shear for all locations Default = H |
| Material Yield | Material Yield for all locations Default = 270 |
| Thickness Influence (TI) | Thickness Influence (TI) for all locations Default = 1.0 |
| Thickness Flag (TF) | Valid keys = t or tmin Thickness Flag (TF) for all locations |
| Intermittent Factor (Z) | Intermittent Factor (Z) for all locations Default = 1.0 |
| Weld Eccentricity (e) | Weld Eccentricity (e) for all locations Default = 0.0 |
| Effective Thickness (Ar) | Effective Thickness (Ar) calclated at each location. |
<Column label="Notch Class - Transverse">x F2 F2
                    F2 F2 F2 F2 F2</Column>Where, Location1 will retain the default value applied by HyperLife Weld Certification.
    <!-- DVS1608 -->
        <WeldData Template_name="T_Example_DVS1608" Weld_type="T" >
	<Table type="Evaluation_distance_table" Evaluation_Distance="Manual" Evaluation_Approach="Hotspot">
                <Column label="Weld Factor">x 1.0 1.0</Column>
                <Column label="Constant 1">0.6 0.6 0.6</Column>
                <Column label="Constant 2">1.6 1.6 1.6</Column>
                <Column label="1st Total Distance">16.0 16.0 16.0</Column>
                <Column label="2nd Total Distance">24.0 24.0 24.0</Column>
          </Table>
	      <Column label="Mean Stress Sensitivity - Normal">0.16</Column>
	      <Column label="Mean Stress Sensitivity - Shear">0.10</Column>
	      <Column label="Grinding Bonus">yes</Column>
	      <Column label="Effective Weld Thickness">No</Column>
           </Table>
	      <Column label="Notch Class - Transverse">x F1 F1 F1 F1 F1 F1 F1</Column>
	      <Column label="Notch Class - Longitudinal">x F1 F1 F1 F1 F2 F2 F2</Column>
	      <Column label="Notch Class - Shear">G x G G G H H H</Column>
	      <Column label="Material Yield">320 x 270 270 270 270 270 270</Column>
	      <Column label="Thickness Influence (TI)">1 1 0.7 0.7 1 1 0.7 0.7</Column>
	      <Column label="Thickness Flag (TF)">t t tmin tmin t t t t</Column>
	      <Column label="Intermittent Factor (Z)">1 1 1 1 1 1 1 1</Column>
	      <Column label="Weld Eccentricity (e)">0 0 0 0 0 0 0 0</Column>
	      <Column label="Effective Thickness (Ar)">10 10 5.6 5.6 10 10 7 7</Column>
            </Table>
        </WeldData>
   </Regulation>
</WeldPropertyTemplateData>Regulation name = dvs1612, Table type = General_table, and Table type = Location_table
| Attributes | |
| Cutoff Value | Default = 0.15 |
| Nominal Slope | Default = 3 |
| Shear Slope | Default = 5 |
| Attributes | |
| Notch Class - Transverse | Notch Class - Transverse for all locations Default = F3 |
| Notch Class - Longitudinal | Notch Class - Longitudinal for all locations Default = F3 |
| Notch Class - Shear | Notch Class - Shear for all locations Default = H- |
| Thickness Flag (TF) | Thickness Falg (TF) for all locations. Valid keys = t or tmin |
| Material Grade | S355 / S235 / UserDefined Default = S355 |
| Material Yield | Material Yield for all locations Default = 355 |
| Effective Thickness (Ar) | Effective Thickness (Ar) calculatred at each location. |
    <!-- DVS1612 -->
    <Regulation name="dvs1612">
        <WeldData Template_name="T_Example_DVS1612" Weld_type="T" >
                <Column label="Weld Factor">1.0 1.0 1.0</Column>
                <Column label="Constant 1">1.5 1.5 1.5</Column>
          </Table>
	      <Column label="Cutoff Value">1.16</Column>
	      <Column label="Nominal Slope">3</Column>
	      <Column label="Shear Slope">5</Column>
            </Table>
                  <Column label="Notch Class - Transverse">x F2 F2 F2 F2 F2 F2 F2</Column>
                  <Column label="Notch Class - Longitudinal">x F2 F2 F2 F2 F2 F2 F2</Column>
                  <Column label="Notch Class - Shear">x G G G G G G G</Column>
                  <Column label="Material Grade">UserDefined UserDefined S355 S355 S355 S355 S355 S355</Column>
                  <Column label="Material Yield">350 350 355 355 355 355 355 355</Column>
            </Table>
        </WeldData>
   </Regulation>
</WeldPropertyTemplateData>Regulation name = fkm, Table type = General_table, and Table type = Location_table
| Attributes | |
| Material Type | steel / al Default = steel |
| Residual Stress factor (KEnormal) | Default = 1.26 |
| Residual Stress factor (KEtau) | Default = 1.15 |
| Mean Stress sensitivity (Mnormal) | Default = 0.15 |
| Mean Stress sensitivity (Mtau) | Default = 0.09 |
| Overload Situation | F1 / F2 / F3 / F4 Default = F2 |
| Temperature Factor (Ktd) | Default = 1 |
| Material Safety Factor (jF) | Default = 1 |
| Load Safety Factor (jS) | Default = 1 |
| Reference Number of Cycles (Nc) | Default = 2e+06 |
| Number of Cycles at Knee point - Normal (Ndnormal) | Default = 5e+07 |
| Number of Cycles at Knee point - Shear (Ndtau) | Default = 1e+08 |
| Slope Exponent - Normal | Default = 3 |
| Slope Exponent - Shear | Default = 5 |
| Thickness Factor | FallA / FallB Default = FallA |
| Exponent N for thickness | 0.3 / 0.2 /0.1 Default = 0.1 |
| If Edge - Layer solidification | Yes / No Default = No |
| Solidification Factor (Kv) | Default = 1 |
| If Material GJL | Yes / No Default = No |
| Material GJL factor (Knle) | Default = 1 |
| Plastic Support (npl) | Default = 1 |
| Weld Line Factor (aw) | Default = 1 |
| Softening Factor (Pwez) | Default = 1 |
| Static Safety Factor | Default = 1 |
| Effective Weld Thickness | Yes / No Default = No |
| Attributes | Value at each location |
| Fatigue Class - Transverse | Default = 100 |
| Fatigue Class - Longitudinal | Default = 100 |
| Fatigue Class - Shear | Default = 100 |
| Material Yield | Default = 270 |
| Thickness Influence (TI) | Default = 1 |
| Thickness Flag (TF) | Valid keys = t or tmin Default = t |
| Intermittent Factor (Z) | Default = 1 |
| Weld Eccentricity (e) | Default = 0 |
| Effective Thickness (Ar) | Effective Thickness (Ar) calculated at each location |
    <!-- FKM -->
    <Regulation name="fkm">
        <WeldData Template_name="T_Example_fkm" Weld_type="T" >
	      <Column label="Constant 1">0.5 0.5 0.5</Column>
	      <Column label="Constant 2">1.5 1.5 1.5</Column>
	      <Column label="1st Total Distance">15 15 15</Column>
	      <Column label="2nd Total Distance">25 25 25</Column>
          </Table>
	<Column label="Material Type">steel</Column>
		<Column label="Residual Stress factor (KEnormal)">1.26</Column>
		<Column label="Residual Stress factor (KEtau)">1.15</Column>
		<Column label="Mean Stress sensitivity (Mnormal)">0.15</Column>
		<Column label="Mean Stress sensitivity (Mtau)">0.09</Column>
		<Column label="Overload Situation">F2</Column>
		<Column label="Temperature Factor (Ktd)">1</Column>
		<Column label="Material Safety Factor (jF)">1</Column>
		<Column label="Load Safety Factor (jS)">1</Column>
		<Column label="Reference Number of Cycles (Nc)">2e+06</Column>
		<Column label="Number of Cycles at Knee point - Normal (Ndnormal)">5e+07</Column>
		<Column label="Number of Cycles at Knee point - Shear (Ndtau)">1e+08</Column>
		<Column label="Slope Exponent - Normal">3</Column>
		<Column label="Slope Exponent - Shear">5</Column>
		<Column label="Thickness Factor">FallA</Column>
		<Column label="Exponent N for thickness">0.1</Column>
		<Column label="If Edge - Layer solidification">no</Column>
		<Column label="Solidification Factor (Kv)">1</Column>
		<Column label="If Material GJL">no</Column>
		<Column label="Material GJL factor (Knle)">1</Column>
		<Column label="Plastic Support (npl)">1</Column>
		<Column label="Weld Line Factor (aw)">1</Column>
		<Column label="Softening Factor (Pwez)">1</Column>
		<Column label="Static Safety Factor">1</Column>
            </Table>
		<Column label="Fatigue Class - Transverse">120 100 100 100 100 100 100 100</Column>
		<Column label="Fatigue Class - Longitudinal">120 100 100 100 100 100 100 100</Column>
		<Column label="Fatigue Class - Shear">100 100 100 100 100 100 100 80</Column>
		<Column label="Material Yield">270 270 220 270 270 270 270 270</Column>
	</Table>
       </WeldData>
  </Regulation>
</WeldPropertyTemplateData>Define Weld Template XML
| Attributes (General Table) | Value at Each Location |
| Scale | Modifies the combined stress calculated during the stress/strain history generation. Default = 1 |
| Offset | Modifies the combined stress calculated during the stress/strain history generation. Default = 0 |
| Kf | Fatigue strength reduction factor, Default = 1 |
| Attributes (Location Table) | Value at Each Location |
| Material - Transverse | Material from Material Database or My Material |
| Material - Longitudinal | Material from Material Database or My Material |
| Material - Shear | Material from Material Database or My Material |
<!-- ERRI -->
<Regulation name="ERRI">
  <WeldData Template_name="ERRI_T_Example" Weld_type="T" >
       <Column label="1st Total Distance">x 15.0 x</Column>
       <Column label="2nd Total Distance">15.0 x 25.0</Column>
    </Table>
        <Column label="Scale">2.0</Column>
        <Column label="Offset">10.0</Column>
        <Column label="Kf">1.0</Column>
     </Table>
       <Column label="Material - Transverse">Mat_SN(4) Mat_SN(4) Mat_SN(4) Mat_SN(4) Mat_SN(4) Mat_SN(4)</Column>
       <Column label="Material - Longitudinal">Mat_SN(2) Mat_SN(2) Mat_SN(2) Mat_SN(2) Mat_SN(2) Mat_SN(2)</Column>
       <Column label="Material - Shear">{Mat_SN(9) XY} {Mat_SN(9) XY} {Mat_SN(9) XY} {Mat_SN(9) XY} {Mat_SN(9) XY} {Mat_SN(9) XY} </Column>
      </Table>
  </WeldData>
 </Regulation>
</WeldPropertyTemplateData>| Attributes (General Table) | Value at Each Location |
    <Module name="SN">
     <WeldData Template_name="SN_T_Example" Weld_type="T" >
       <Column label="1st Total Distance">x 15.0</Column>
     </Table>
       <Column label="Scale">10</Column>
       <Column label="Offset">20</Column>
       <Column label="Kf">30</Column>
     </Table>
      </Table>
     </WeldData>
   </Module>
