Control Cards
Control cards allow you to add input and output parameters to a model, including location and names of the input, output and scratch files; the type of run (analysis, check or restart); overall running of the analysis or optimization; and type, format and frequency of the output.
Control cards are assigned to your model from within the Control Cards panel. This panel lists all of the control cards defined for the solver/user profile that you currently have loaded; you can disable, enable, or delete cards as desired.
Use the Card Previewer
| State | Color | Explanation |
| Undefined | Gray | The control card was either never created or has been deleted. |
| Defined (See note.) | Green | Any control card viewed in the card previewer is activated. |
| Inactive | Red | A card that has been defined may be disabled. The attributes for that card remain; however, the control card is not output. |
| State | Description |
| Default = ON | In this state, the field label color is yellow and no data entry is allowed. |
| Default = OVERRIDDEN | To override a default value field, pick the yellow field label. When you override a default value field, the label text color changes to cyan and allows you to enter data in the field. |
