Fit Automatically Selected by Training
Selects the best available Fit from a list of available methods you have chosen. In addition to selecting the best method, Fit Automatically Selected by Training also automatically adjusts the individual settings (often called hyperparameters) to find the optimizing, predictive performance while avoiding overfitting.
Usability Characteristics
- Fits both noisy and non-noisy data.
 - Reduces the methods on which Fit Automatically Selected by Training iterates in order to reduce the run time used to build the Fit.
 - Can run in multi-execute, while simultaneously iterating over multiple responses.
 - The Stepwise Regression Terms option for Least Squares Regression reduces the number of coefficients in the regression model to contain only the set that is statistically significant.
 - The behavior and characteristics of the underlying methods are the same as when the methods are directly applied. See their respective documentation pages for details.
 - Gradient information can be used to boost performance for the methods that support gradients.
Settings
| Parameter | Default | Range | Description |
| Least Square Regression | On | On or Off |
| Stepwise Regression Terms | Full Quadratic |
                                Controls the maximal set of terms considered in stepwise
                                        Least Squares Regression.
| Moving Least Squares | On | On or Off |
| Radial Basis Function | On | On or Off |
| Use Gradient Data | On | On or Off |
