Test Models
Write input files, execute analysis, and extract output responses for models defined in the study Setup.
- Go to the step.
                Define optional settings.
- To receive a notification when a task is completed, click
 and activate
                            Notify. - To write the solver output in the Message Log
                        window and/or log-file, click
 and activate Log External
                            Output. - To change the number of concurrent jobs to run, click
                            Multi-Execution and enter a new number; it does
                        not have to be a static entry. Click
 to choose whether
                        Multi-execution runs jobs in vertical, horizontal, or horizontal (write all
                        first) execution mode.- Vertical execution mode performs the write, execute, and extract tasks for all designs simultaneously; that is all designs are written, then executed, then extracted.
 - Horizontal execution mode sequences the write, execute, and extract task for each run independently.
 - Horizontal (Write all First) execution mode sequences the write task for each run first, then sequences the execute and extract tasks for each run independently.
                Run definition tasks (write input files, execute analysis, and extract output
                    responses) in the following ways:
- Concurrently run tasks for all models in the definition by clicking Run Definition.
 - Concurrently run tasks for an individual model in the definition by clicking All in the Test column of the model to run.
 - Select an individual task to perform by clicking Write, Execute, or Extract in the Test column of the model to run.
