DOE Output Files
Output files generated from a DOE.
<doe_variable_name>.hstds
- File Creation
 - This file is created when Apply is selected during the Specifications step.
 - File Location
 - <study_directory>/approaches/<doe_variable_name>/<doe_variable_name>.hstds
 - File Contents
Result Format Description Run Matrix Data hstds, binary Hstds files stores the retained data sources; direct access data using the .hstds file is not suggested.
<doe_variable_name>.hstdf
- File Creation
 - File Location
 - <study_directory>/approaches/<doe_variable_name>/<doe_variable_name>.hstdf
 - File Contents
Result Format Description Run Matrix Data hstdf, binary Hstdf files store the run data; however, direct access to the data using the hstdf files are not suggested.
