Delta Summary Post Processing
View the difference between run and reference data.
View Delta Data Summary
View a detailed summary of the differences between input variable and output response run and reference data in a tabular format from the Delta Summary post processing tab.
- From the Post Processing step, click the Delta Summary tab.
 - Using the Channel selector, select the channels to display in the delta summary table.
 - Analyze the summary.
